Nouveau utilisateur avec un Prosimu T1000 2 dof
Discussion in 'Commercial Simulators and Peripherie' started by Foehn, Nov 30, 2015.
  1. insanegr
    insanegr !N$@n€
    Athens
    16,722Coins
    @dJuL did you go in control panel - region and language and change Format , Location tabs and on administrative tab the Language for non-Unicode programs , into English?
    give it a try if you haven't done all three changes
    • Friendly Friendly x 2
  2. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Yep I think...
    Region & Language window has changed under windows 10, but I set English / US everywhere and it wasn't enough.
    Fortunately it's easier to put the "." into the clipboard and past it with the context menu, it works fine and I can keep my keyboard in AZERTY and my regional settings. ;)
    Also I finished all my new settings for AC with lower axis %
    It seems good but I have to practice to be sure, I was used to use my old settings since a long time and before today I didn't pay attention of how exactly the sim reacted since I made the first settings last year...
  3. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Fohen, how frequency have you set on the Crossover (80, 125 or 250 Hz)?
    And you have fueled him or it is simply inserted along the mounting scheme?
  4. fortissimo
    fortissimo Member
    france
    161Coins
    beautiful facility
  5. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    Cut your principal HP to do some test with only the basspump and test the 3 positions
    more this setting will be down and less you will have all frequencies (for the bass, you must have low)
    I don't use the crossover at this moment because I added a mechanical-component inside my amplificator
  6. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Hello All,
    After the long period of testing, I think I know well now how to work SimTools and I start to have a good feeling of my Simu.
    I share you my Global settings, for PCars (for the beginning)
    T500RS Control Panel - 900°
    SimTools - Game Engine - Interface
    SimTools - Game Engine - Axis Assignments
    SimTools - Profil Editor - Main
    SimTools - Profil Editor - Editor
    SimTools - Tuning Center
  7. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    And for Assetto Corsa
    The settings of my T500RS are the same for me and for AC & Pcars
  8. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    And some pictures
  9. piorck
    piorck Member
    french
    258Coins
    it's very beautiful!!
    you can see all you screen when you driving ?!!!
  10. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    like in real driving, only one time by lap and during the big line
  11. Wanegain
    Wanegain Active Member
    Bruxelles
    2,001Coins
    Ho wow ! Your rig is very complete !
    I did not know that you could use another screen for apps in Assetto Corsa o_O
  12. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    3 screens are merged in one (5960 x 1080), more one screen alone
    You can use the last one for what you want
  13. Icefox
    Icefox Member
    549Coins
    Jolie poste de pilotage :thumbs
  14. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Merci Icefox, j'y ais travaillé depuis 3 mois
  15. fortissimo
    fortissimo Member
    france
    161Coins
    ca envoie,et merci pour les setups de simtools ;)
  16. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    ce soir, je posterais les réglages pour les auto LMP car ils changent un peu dans le Profil Editor
  17. Wutty74
    Wutty74 New Member
    Berlin
    149Coins
    2DOF, SCN6
    hi many thanks for the quick response. when I search the game pCars the game manager, I think it's just life nicht.es 4 speed available. the game path (installation path) from playing he not accepted. What can I do.
  18. Icefox
    Icefox Member
    549Coins
    Est-ce nécessaire de toucher au réglages dans Profil Editor-Editor ? car il y a déjà Game Engine Axis Assignments et Tuning center tu coup je me pose la question :!
  19. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Yes IceFox, all are linked and it's very important to customize them
    Game Engine - Interface is set (and commun) for all games (my opinion)
    Game Engine - Axis Assignments : different for the games
    SimTools - Profil Editor - Editor : to adjust in the game related the track or the cars (Gt ; Lmp, etc)
    Oui Icefox, tout est lié et indissociable
    Dans l'ordre
    Le Game Engine - Interface est réglé (et commun) pour tous les jeux et suivant ton ressenti.
    Le Game Engine - Axis Assignments : différent suivant les jeux
    Le SimTools - Profil Editor - Editor : pour ajuster dans le jeu suivants les circuits ou autos
  20. Historiker
    9,208Coins
    Moved to the commercial simulator forum.
    By all means use your own language in posting in this forums but also post a translation in English.
    The French forum is for social discussion only, build thread and simulator questions should be in their proper section.
    Thank you for your cooperation
