This plugin is actually for a testing tool, not a game. It allows an Android device to be used as a virtual vehicle by reading data from the app Sensor UDP. Moving and rotating the device causes the simulator to move in a corresponding manner.
Steps for use:
Motion data: Roll, pitch, yaw, heave, sway, surge
- Download and install the plugin in the usual way, using PluginUpdater.
- Extract the file SensorUDP_Connect.exe from the downloaded zip file, and run this executable. This acts as the "game" running on the computer.
- Download and install Sensor UDP on an Android device. Run this app and enable acceleration and orientation data, and enter the IP address and port number displayed in SensorUDP_Connect.exe. The IP should be the computer's internal IP address (e.g. 192.168...) and the port should be 20777.
- Open GameManager and GameEngine on the computer and push the Send Data button in the app. Data should now be transmitted from the app to SensorUDP_Connect.exe, which then transmits it to SimTools.
Author: Icy7CE
