X-Sim and speed related blower fans
Discussion in 'DIY peripherals' started by SimonME46, Jan 19, 2009.
  1. SimonME46
    SimonME46 New Member
    Canberra, ACT, Australia
    Apologies if this has been asked before, I have tried searching..
    I have a couple of bilge blowers which are able to blow air in my face to give an enhanced sensation of speed, one of my friends who is literate about electronics (I am not) is helping me to get this up and running.
    My questions
    1. does X-Sim have a 'speed' out put which could be used to govern the speed of the fans?
    2. and is it possible to have X-Sim and Frex listening to the game at the same time?
    3. If I was to convert away from Frex, would I just need to d/l the software and buy 2 x USB - RS485 converters, and pretty much go play the games that Frex doesn't support
    If these Q's are covered elsewhere, please just point me at the threads...
    Cheers
  2. egoexpress
    Re: X-Sim and Frex
    @Simon
    Welcome!
    1. X-Sim is able to output dynamic values to external hardware interfaces/controllers.
    But with these signals you wont be able to drive a motor directly. You will have to amplify the PC signal with a motor driver like a h-bridge for example.
    So you will need the following:
    -hardware controller interface (Velleman k8055 for example or others)
    -driver (amplifier) like an h-bridge or other motor drivers.
    You probably should ask Thanos for further advice.
    2. Imho you should use both, the SCN5 and the fans, with X-Sim only. That would make the issue with making X-Sim work besides the Frex driver obsolete.
    3. I wouldn't say each and every game, but a bunch more. And at least no driver update is needed with every game update in most cases :brows:
    And yes, you would need just 2 cheap converters and the software, as you have the power supply already. BvillersJr has gathered some experience with SCN5, and would help you for sure with the connection.
    Btw, in case you would like to drive a rally race with a co-driver, you could easily change your SCN5 axis numbers to equal values, so that both SCN5 rigs would respond to a single output (that means both rigs would move in sync).
    EDIT: Oh, I see you are using 2 computers. In that case you could send the game data via the Force-Sender to the second computer as well. No need to change axis assignments at all.
    Regards
    Christian
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    Re: X-Sim and Frex
    I think his second computer may be because he has 2 Frex's installed. If that is the case, then he has one PC per Frex.
    A couple of other people have converted their Frex systems to X-Sim with good results. However, it is not a plug and play type of swap. For example, you will need to remove the plugs on your actuators and wire them to the RS485 adapters and power supply that you purchase.
    Additionally, X-Sim is not as easty to use as the Frex system (not yet anyway, but I'm working on a solution to that) but it is alot more powerful! If you are up to the task, then egoexpress is correct, an all X-Sim solution would be the best way to go, and I can help you through the process.
  4. egoexpress
    Re: X-Sim and Frex
    That is right. I was aware of that. He simply has to install the X-Sim software on both computers. Then he has to start the game on a single computer and establish a cluster network in the Force-Sender (by adding the IP numbers of both computers in the Force-Sender), which delivers the game data to the second computer as well.
    So the game data of one computer is delivered to both computers respective both SCN5 rigs ;D
  5. bvillersjr
    Ohio, USA
    437Coins
    Re: X-Sim and Frex
    I see. I assumed that they were entirely independent so that two people could race against each other.
  6. egoexpress
    Re: X-Sim and Frex
    That is right as well. I just suggested that it could be set up optionally to have both rigs moving simulatneously as well. That way a co-driver could take place on the second seat.
  7. SimonME46
    Re: X-Sim and Frex
    Thanks for all the responses! - most helpful, and from the people who know what they are talking about.
    Just to confirm, yes there are 2 PC's, one for each Frex rig, and normally we race against each other, they are on the same LAN.
    I'm very interested in going over to an all X-Sim solution. In terms of the fans, one of my geeks is putting together a motor controller using a microprocessor, he plans on having it run on the X-Sim bus (using a jaycar 10AMp kit as a starting point).
    If I can match the connectors, I'd probably tend to make my USB - RS-485 connect to the existing SCN5 plugs rather than cut the plugs on the SCN5s. Wouldn't the current power supply connection stay in place?
    @ bvillersjr - Garth (my geek) asked if you are running an RS-485 bus - as there seemed to be one adapter per SCN5? Garth is going to read the documentation which will probably answer the Q's he has.
    Sounds like at the end of this process I should provide a Frex - X-Sim conversion thread so that gumbies like me who are only good for plug'n'play can have a step by step guide?
  8. bvillersjr
    Ohio, USA
    437Coins
    Re: X-Sim and Frex
    I can't comment on the interfacing of the Jaycar product to X-Sim, but if it has a serial interface, then it is likely that it can be made to work with X-Sim. Several others have more experience than I in this area, but it seems that they prefer Velleman or Pololu interfaces.
    Actually, yes, you should be able to use your existing power supply if you stay with the Frex cables and purchase opposite gender plugs to connect to RS-485 adapters. In your sim design, it seems that the cables may not be visible. In other designs, they are an eye-sore. I replaced them all together with a single-wire solution that connects to the circuit inside of the white plastic cap on the SCN5's.
    I use two USB<-->RS485 adapters. A complete part list for my build can be found here: http://www.x-simulator.de/forum/post10861.html#p10861
    Please, do. It's this essential exchange of knowledge that keeps this community alive.
  9. egoexpress
    Re: X-Sim and Frex
    <a class=postlink-local href=http://www.x-simulator.de/forum/post12751.html#p12751 target=_blank>post12751.html#p12751</a>
  10. SimonME46
    Re: X-Sim and Frex
    Thanks for the link on the speedo/servo controls, and for the links to the pololu boards etc. I checked out bvillersjr thread and noted the 2 x USB=>RS485 - we were going to buy the same units but postage costs were a killer, we've ordered some local units.
    The fans that I am using are Rule Bilge Blowers 12V 4.3A, however startup current was 8.6A. I'm using these because I have some 75mm ducting off a real race car, and normal household fans don't push enough air to make a difference/can be 240V which I'd prefer to stay away from. The 100mm blower pushes 235cfm, which at 100mm duct should push air in my face at about 55km/h. By stepping down to 75mm, I should get close to 90km/h, which actually might be too much! [​IMG]
    This is all looking positive!
  11. SimonME46
    Re: X-Sim and Frex
    Your suggestion is an excellent plug and play option, I like it.
    Given Garth's input, we'll end up with a significantly cheaper kit built option, which we'll post up for others to consider.
    Cheers,
  12. SimonME46
    Good news - Garth has the boards together and has been controlling the fans in a test environment. Game plan at this stage is to plug them in on Friday and give them a trial run, see how his programing responds to the game outputs. I will then start carving up the mini to fit them in (should only be 2 x 75mm dia holes for the ducting, and a couple of rivet/wiring holes in the front guards).
  13. SimonME46
    I have one of the fans installed and working, need some time to install the fan on the other side of the car. X-sim was amazingly easy to work with. We have one small 'unintended feature' which is a bit of a blip in the speed at low speeds, seems to iron out as it gets going faster.
    This really adds another dimension, really give a sensation of speed/slowing down, even though I've never had such ventilation in real life (I'd be interested to hear if real life race drivers could comment on ducting). I'm not sure how to share this, but I suspect that a video will give the wind noise idea!
  14. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Try to instal fringes infront of outlet. Then we can see how mutch is air blowing.
  15. mrpio
    mrpio New Member
    Bump. Any news? Photos? Please?
  16. SimonME46
    Both sides installed in the mini, works really well and gives a great impression of speed. Actually gets a bit cold on the face, although it does adress a stuffiness problem in the car. They also pick up the smoke from the smoke machine (installed under the bonnet) and blow it into the car! Pls excuse the driving - one handed was harder than I thought...
    http://www.youtube.com/watch?v=A7EvtJy2UBg
  17. RaceRay
    23,842Coins
    Are u kidding? You driving looks nearly perfect when you touch the curbs in left right turns :clap:
    What´s the reason for smoke generating under the bonnet except simulating water cooling problems :) ?
    br
    René
  18. egoexpress
    Good job!
    Could you tell us more details about the hardware you are using, and how you hooked it up to XSim?
    Some pics would be appreciated.
    Regards
    Christian
  19. SimonME46
    Hehe - there were a few doors left wide open, esp on right handers.
    Engine on fire after smashing into the wall? - I use it as a trick when we have parties and people give the sims a go and crash into the wall. When ppl don't know ot's there, they poop themselves and think there is some sort of an electrical fire....
  20. mrpio
    mrpio New Member
    Great news! Can we expect to get some more technical info about this long-awaited innovation? Thanks in advance!
