Tronic's AMC 1.5 Flashen Bitte um Hilfe
Discussion in 'DIY peripherals' started by Asus-G51JX-3D, Aug 15, 2014.
  1. Asus-G51JX-3D
    Asus-G51JX-3D Member
    - 69Coins
    2DOF, 4DOF
    Hallo
    Könnte mir einer eine Anleitun schicken wie man mit
    PonyProg2000 den Tronic's AMC 1.5 controller Flasht ? Danke
    Und wo bekomme ich noch die Firmware
    PWM_AMC15_2DOF_V1_CRYSTAL14.HEX
    und die
    PWM_AMC15_2DOF_V1_CRYSTAL24.HEX
    her die beiden anderen FW ( 18 und 22 ) habe ich noch
    Danke
    Thx Tronic's
  2. eaorobbie
    20,401Coins
    Buy a cheap Ard UNO mate, or maybe able to flash it with a modified code, I think @speedy uses the AMC with a custom firmware. He might chime in and advise.
    But the other option is to use a Ard and there is plenty of help here to get it moving along quickly, or back working again.
  3. Asus-G51JX-3D
    - 69Coins
    2DOF, 4DOF
    Hello eaorobbie
    I have since 4 years now my simulation with the AMC 1.5 and everything works fine :grin
    Now I have one built for my brother and i have already soldered the AMC 1.5
    I only know, unfortunately, no longer how i to flash the AMC
    has any one guide how i flash the AMC 1.5 :sos
    Thx Tronic's
  4. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,918Coins
    I'm using the Revolution firmware and software for AMC1.5+1.6
    by @prilad
    that have the USB connection capability for the ATMEGA8535 & 644 when you don't have 232 serial port .
    with many many options in the SW for mechanical calibration and maintenance ...
    easy to flash and perfect to use ...:thumbs
  5. Asus-G51JX-3D
    - 69Coins
    2DOF, 4DOF
    Hallo
    Ich brauche nur eine Anleitung, wie ich blinken die Firmware auf dem AMC 1,5
    Wie auf dem Video nur, dass Sie nichts sehen
    Thx für schnelle Hilfe
    Thx Tronic
  6. speedy
    Alexandria , Egypt
    7,918Coins
    from the last 3 seconds in this video ... I guess you programmed it OK and the AMC is in the remote terminal mode :thumbs... So you have 2 problems ...
    - one is the LCD contrast ... try to reduce the Vcc to it ...
    - the second is restart the AMC with the dip switches back to normal and without the 5 wires programming jump then connect the serial cable to the other 9 pin port so you can use the Rx/Tx data bus ...
    Good luck .
  7. Asus-G51JX-3D
    - 69Coins
    2DOF, 4DOF
    Hello speedy
    The video is not mine I am looking for a manual as the
  8. speedy
    Alexandria , Egypt
    7,918Coins
    Ok ... you can find all manuals and files in the link above ...
    I highly recommend it with the same AMC 1.5 hardware you have .:thumbs
