PC Power supply 750 Watt enough?
Discussion in 'Electronic and hardware generally' started by Michael Hensen, Apr 19, 2014.
  1. Michael Hensen
    Michael Hensen Active Member
    C# Software Engineer
    Almere, Netherlands
    748Coins
    Is a PC power supply of 750 watt like the Corsair CX750M be enough to power the monster moto shield with 2 zyt-90 motors? Or will it be too low on max current?!
    I have a 175A PSU but it sound like a vacuum cleaner :)
    Thanks in advance,
    Michael
  2. bsft
    volts divided by watts = amps , so 62.5 amps, but it depends on what the actual 12v current is.
    And 62 amps max, probably not, you can still run a sim, but fairly soft motion. Best allow 40 amps per motor. Minimum.
  3. Michael Hensen
    Almere, Netherlands
    748Coins
    Hmm .. in that case I hold on to my 'vacuum' cleaner..
  4. bsft
    just turn the volume up and or wear headphones
  5. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    HP G4 server power supplies are what you need. 15GBP each from ebay and they're 47A each.
  6. Michael Hensen
    Almere, Netherlands
    748Coins
    are they loud?? that is the main question.. And I assume I could join 2 of the HP G4 supplies to double the amps combined or will this give trouble?
  7. Pit
    30,417Coins
    Server power supplies are in most cases loud. THe question should be it works or not, I use a server psu and winches but if the speaker is loud enough (and not too loud at all) I don't hear anything from my rig.
  8. Roadster2
    Roadster2 Member
    1,194Coins
    Hi Michael. Your Server power supply is capable of supplying 175A and the three internal fans are capable of keeping it running when supplying this massive amount of current. With the motors drawing around 32A each you could quite happily run on half of the rated output. What you might want to consider therefore is fitting some small voltage droppers in line with each of the three fans, reducing the voltage will significantly reduce the noise. From memory I think the fans are 12V so you could look at dropping this to 7V or 6V quite comfortably.
    The reducers I'm think of are very small enclosed circuit boards. If I can find a link I'll add it here.
    As a simple solution you could use a heavy duty wirewound resistor to drop the voltage but you would then need to be careful where you sited the resistors because of the heat they would generate.
    Note: the fans have a feedback wire so the voltage droppers need to be fitted to the +ve and -ve supply lines only. The power supply will shutdown if the fans are not running at all, or if they're running very slow. Running at half speed should be Ok.
  9. Michael Hensen
    Almere, Netherlands
    748Coins
    Thanks Roadster2!! That is a good suggestion, I was thinking in that line but didn't dare to go that way. It is almost scary to turn it on right now :)
    Well the first time I turned it on I turned it off immediately as I thought something might be wrong, the second time I dared to let it run till it quited down a bit.. That was when I thought it might be alright :)
    If you can find a link please let me now, I will try and search too..
    thanks in advance!!
  10. Roadster2
    Roadster2 Member
    1,194Coins
    Hi Michael. I've found cheaper units than this in the past but this is the sort of device I'm suggesting - http://www.dimensionengineering.com/products/anyvolt-micro. These are basically a small Switching Voltage Regulator. Because of the way they work they don't generate heat as a normal voltage regulator IC would, so easy to heat shrink and tuck into a void somewhere.
    Another option could be to obtain the information from the internal fans and to source replacements of the same size but slower running and quieter. Dell often use proprietary connectors so the original connectors may need to be removed and attached to the new fans.
    I still have one of these power supplies for sale so given a bit of time I could open it up and check to see what fans are fitted.
  11. Michael Hensen
    Almere, Netherlands
    748Coins
    I think I've found what you mean.. you gave me the correct search criteria with the anyvolt micro..
    Something like this http://www.ebay.com/bhp/lm2596
    And I guess I need 2 of them
    1 in the front and 1 for the combined 2 fans at the back..
  12. Michael Hensen
    Almere, Netherlands
    748Coins
    Well as I had to order some parts ..Like a new arduino Uno.. I just ordered 2 of these LM2596 along with the rest.. I'll just give it a shot..
    Hopefully the PSU isn't smart enough to raise the RMP when it sees the RPM went down, if it can see it :)
  13. BlazinH
    16,575Coins
    Since no one answered this question yet, I will. Never "assume" anything if you want to be on the safe side. Do not consider a power supply to be like a battery. Power supplies today are usually switching types which mean they only produce the amount of current needed based on what is drawn on them. Usually you can't link them together to supply more current because the current produced by one, effects the current output produced on the other! Some can be linked however but you must be sure they have to capacity to due so first. Some use special pins to link their signals together. While the HP G4 power supply is hot swappable, I don't know if this means they are linkable or not.
  14. bsft
    Seriously @Michael Hensen , why are you so concerned with fan noise? Fans make noise and do a job.
