Automobilista plugin work around
Discussion in 'SimTools Plugins' started by Daguru, Mar 2, 2016.
  1. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    Hi all,
    This is a workaround until a real plugin can be made (by the plugin masters) lol
    used @Avenga76 idea heres what i did
    in the Automobilista folder renamed AMS.exe to GSC.exe patched game with GameStockCar_plugin in the normal way then renamed the exe back to AMS.exe
    then found a cmd.exe copied to desktop renamed it GSC.exe run it then started automobilista and bingo motion
    • Winner Winner x 5
  2. BlazinH
    16,650Coins
    Another method if you don’t have Game Stock Car Extreme (or older versions) on you computer too (since this title is its replacement) is once patched as stated above just leave it named GSC.exe and execute it directly using that exe name.
  3. Matthias Griese
    Matthias Griese New Member Gold Contributor
    - 12Coins
    It doesn´t work for me. Do I have to copy the AMS.exe to the Desktop and rename it to GSC.exe. Then run the cmd.exe and type in under the desktop folder gsc? The game is starting but without motion. Where is my mistake. I did the steps before too.
  4. BlazinH
    16,650Coins
    No. Just rename cmd.exe to gsc.exe.
    Did Simtools tell you that your patch was successful?
  5. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    In the Automobilista folder renamed AMS.exe to GSC.exe patched game with GameStockCar_plugin in the normal way then renamed the exe back to AMS.exe
    Go to C:\windows\system32
    Copy cmd.exe on your desktop and rename it to GSC.exe
    Run GSC.exe (simtools turns blue)
    Run the game.
  6. Matthias Griese
    - 12Coins
    I fixed it now. First I unpatche GSC. Then I renamed the AMS.exe to GSC.exe and patched it. Started the Sim with the GSC.exe and running fine.
  7. value1
    14,936Coins
    • Like Like x 5
