Discussion in 'Electronic and hardware generally' started by gpau, Nov 23, 2015.
  1. gpau
    gpau Member
    550Coins
    Ciao,
    quante schede arduino servono e trasformatori di corrente servono per il funzionamento di 6 motori
    I motori degli argani o pompe elettriche per l'acqua potrebbero essere utilizzati come motori?
    I motori dei tergicristalli da 16nm riesco a fare funzionare e sostenere il peso della struttura superiore del 6dof?
    Grazie
    145,226Coins
    +10,782 / 52 / -2
  3. gpau
    gpau Member
    550Coins
    OK, grazie
  4. gpau
    gpau Member
    550Coins
    Non riesco a capire che tipo di motori sono, avete dei consigli su che motori utilizzare che non siano troppo grossi?
    grazie
  5. gpau
    gpau Member
    550Coins
  6. gpau
    gpau Member
    550Coins
    Questi potrebbero andare bene per un 6dof
    145,226Coins
    +10,782 / 52 / -2
    I can't read the specifications of the motors in the picture.
    You really need a design plan first, then look at motors, Power Supply Units, control boards and pots.
    A 6DOF is a complex and costly project. It is a good idea to first build a model like @hooshang's to get some idea of what it takes to construct and configure a 6DOF, before committing significant time and resources: http://www.xsimulator.net/community/faq/build-a-model-to-test-your-design-ideas.136/
  8. Pit
    30,418Coins
    Please can you share the source of the motors?
  9. gpau
    gpau Member
    550Coins
  10. gpau
    gpau Member
    550Coins
    how do I make this move with sim tools game engine
    145,226Coins
    +10,782 / 52 / -2
    Do you mean as a Sketchup model, if so see here: http://www.xsimulator.net/community/faq/design-software.114/
    If you mean the real thing then you really need to explain a bit more about what actuators are to be used and the thoughts behind the design you have chosen, instead of a tradition 6DOF.
  12. Playsimulator
    Playsimulator Member Gold Contributor
    france la voulte sur rhone
    178Coins
    3DOF, Arduino
