Anyone ever connected Scn6 to Simtools ?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by patritti, May 10, 2014.
  1. patritti
    patritti simracer
    composite race car parts manufacturing
    woodstock GA usa
    516Coins
    3DOF, SCN6
    any one successfully connect scn6 to simtools ?
    I was able to connect scn5 to simtools . work very good .
    but can not make scn6 work .
    they work with other motion software . so i know the wiring is right .
    please advice .
    Pat
  2. bsft
    ask the people whom helped you with SCN5 setup
  3. nclabs
    196Coins
    I have the same issue, my SCN5 sim it's working, but not the big one with the SCN6, is there some problem in the software that need a fix?
  4. bsft
  5. patritti
    patritti simracer
    woodstock GA usa
    516Coins
    3DOF, SCN6
    Yobuddy is working on it . Soon we will have a solution .
    Sent from my iPad using Tapatalk
  6. yobuddy
    48,260Coins
    Yes, this will be worked on very soon!
  7. nclabs
    196Coins
    Hey guys, do you have any news about this? My friend is going mad awating this update!
  8. patritti
    patritti simracer
    woodstock GA usa
    516Coins
    3DOF, SCN6
    just checking . any update to make cnc6 compatible with sim tools !
  9. yobuddy
    48,260Coins
    I still have not received the test actuator that I was borrowing to make this happen - :(
    My guess is that my startup routine has a value that is out of range for a scn6.
    Maybe I can put together a test app in order to find values that will work for both.
    There just are not enough hours in a day lol :thumbs
  10. patritti
    patritti simracer
    woodstock GA usa
    516Coins
    3DOF, SCN6
    if you want i could fedex you a cnc6 next week if that help .
    regards pat
  11. nclabs
    196Coins
    That's would be awesome! I can give my support too, if you have any app to try, just ask, I will do that for you. I hope it will be enough :)
  12. nclabs
    196Coins
    @yobuddy did you received the SCN6 from patritti?
  13. yobuddy
    48,260Coins
    Yes - and I think i got it working!!
    But, my new ssd hdd crashed!
    So i need a week to get everthing back up and running.
    (I have to wait for the replacement ;) )
  14. nclabs
    196Coins
    This is a mindblowing news, just before holidays!
  15. yobuddy
    48,260Coins
    there are a few startup 'home' commands the scn6 don't support.
    It was just a matter of using homing commands that worked for both the scn5 and scn6.
  16. logic1208
    logic1208 its more safe for me, to drive sims ;-) SimAxe Beta Tester Gold Contributor
    switzerland
    533Coins
    SCN5
    @yobuddy
    does it mean, it works now ?
    want to build my second motionrig as d-box style ;-)
    any suggestion which version of the scn6 would be the best vor this projekt?
  17. yobuddy
    48,260Coins
    @logic1208
    Yes, we are testing and fine tuning it now... :thumbs
  18. patritti
    patritti simracer
    woodstock GA usa
    516Coins
    3DOF, SCN6
    Yes Simtools is compatible with CNC6 . running Every day for week now .
  19. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    And what was the solution? Perhaps I have same issue.
  20. nclabs
    196Coins
    Man, this is not a joke. I've been thinking about it a lot lately. You have PM
