WN_Controller 6 axis 10 bits + 36 buttons with PIC18F2455
Discussion in 'DIY peripherals' started by willynovi, Nov 4, 2009.
  1. willynovi
    willynovi Member
    Argentina
    354Coins
    I built this controller for my proyect of steering wheel, pedals and buttons box / h shifter, but it can be used for any kind of control.
    It´s based on a PIC 18F2455 and it´s very simple to buid.
    Here is a link to the original web in XtremeRacers Forum in spanish.
    http://www.xtremeracers.info/forums/vie ... =45&t=5696
    In some time, no too much far away, I´m doing a translate to english.
    English Version by Andy: Download Controller Manual Ver 0.1.pdf for free on uploading.com Released 28/03/2010
    Here are the files you need to build this controller.
    It´s seems to be too big, but i´m trying to compress it.
    Feel free to do any coment or improve.
    Regards
    Willy
  2. RaceRay
    23,837Coins
    If you need help in uploading any documentation let me know. Thanks for sharing your work. Hope to see the docs in english soon :)
    CU
  3. willynovi
    willynovi Member
    Argentina
    354Coins
    The entire file is 2Mb and I dont have any service of upload.
    Could you propouse me any form to upload the file?
    Willy
  4. NuMcA_[.gr]
    NuMcA_[.gr] New Member
    3Coins
    Thank you for the project Willynovi!
    Why don't you try uploading it at RAPIDSHARE?
  5. willynovi
    willynovi Member
    Argentina
    354Coins
    NuMcA, its ok.
    You can follow the link to XtremeRacers and there are the files to download. You dont need to be a register member to do this.
    Any way, I´ll try to upload the files in this forum.
    Regards
  6. tirta
    tirta Member
    Hi willynovi,
    I am also interested in your WN_Controller 6 axis 10 bits + 36 buttons with PIC18F2455.
    please post the english version, if you have translated it.
    Also, I have tried downloaded this:
    http://www.xtremeracers.info/web/index. ... 8&cid=3058
    But I can not find the download button.
    Since I do not understand spanish, I can only guess that you have to be a member to download it.
    With warmest regards,
    Tirta
  7. crobol
    crobol New Member
    You must be registered at XR to download, but it easy, only 2 minutes. If you have any problem you can contact at info[]xtremeracers[]net
    Willy has made 3 versions of firmware to the same PCB :
    6 axis 32 buttons
    4 axis 64 buttons
    0 axis 81 buttons.
    You don't need to understand Spanish to make the PCB or program de PIC... :yes:
    Come on, Try it.... :thbup:
  8. Andy
    Andy New Member
    Hi Willy,
    I've just downloaded your stuff and started the translation :( . Once it is done I'll PM you, so we can get in touch with the forum Moderators and see if they like to host the stuff. I know that is a very good project and should be published here also in order to close the gap between ATMega and the Wonderful and faster PIC. :clap:
    Keep your good work up, you are a good guy to share such infos. :cheers:
    Regards
    Andy
  9. willynovi
    willynovi Member
    Argentina
    354Coins
    Ok Andy, thank you for beginign the translation, when it´s done please let me know so I can see it.
    Talking about ATMega vs PIC, I think the two are very good microcontrollers, I choice PIC because it´s a long time since I manage it.
    Any info you want to share with us about PIC and the HID controller feel free to share it.
    regards,
  10. Andy
    Andy New Member
    Hi Willy,
    I've just finished the translation for your tutorial :yippiee: , it is in a PDF format. I have the file, PM me with your email, so I can mail it to you.
    Also :sos: I need to know which JDM are u using, the one mentioned in your documentation will not handle the 28 pin MCU's. Please let me know and if u have a PCB layout and/or a circuit diagram I'll appreciate it if you post them at this thread or PM them to me.
    There too many version on the net, but If I am going to build your board I have to use a similar programmer to the one you are using. :yes: that makes things much easier when it comes to debugging.
    Regards
    Andy
  11. willynovi
    willynovi Member
    Argentina
    354Coins
    as I know, the email address is in my personal data, send me the translation so I can check it.
    The programer I use is the same as this JDM http://perso.wanadoo.es/pictob/jdm.htm
    It work with any PIC wich support ICSP (In Circuit Serial Programming).
    The Pins in PIC are always the same, don matter wich models or pin counts, you only need the particular datasheet to know that.
    You need this configuration to programm 18F2455/2550
    JDM side - PIC side
    MCLR - Pin 1
    VSS - Pin 8
    VDD - Pin 20
    RB6 - with an100 ohm resistor in serie to Pin 27
    RB7 - Pin 28
  12. Andy
    Andy New Member
    Hi willy,
    Thanks for your prompt reply, I'll start building the programmer this Sunday, and I'll let you know the results :lol: .
    Please check your PM.
    Andy
    PS. I also started reading the Framework documentation, so I might be able to help with the software development.
  13. Andy
    Andy New Member
    Hi willy,
    I've send you another PM with my private mail address, so can you mail me, then I'll mail you the file. I cannot find a way to attach the file from within the forums mail, if you know how just let me know.
    Regards
    Andy
  14. willynovi
    willynovi Member
    Argentina
    354Coins
    I have update the first post with the english translation, thank you Andy for your work.
  15. GeorgeBoles
    GeorgeBoles Member
    4Coins
    Hi WilliNovi,
    I have just downloaded the English translation for this controller and found that the following links do not exist any longer. Is there anywhere else I can get them please?
    Getting PIC18F2455 Bootloader
    http://uploading.com/files/YHIMECEX/MCH ... r.hex.html
    MCHPFSUSB Framework v2.4
    http://www.microchip.com/stellent/idcpl ... m=en534494
    Also does the JDM programmer need an adaptor of some type, because the information doesn't list PIC18Fxxx as one that it works for.
    Thanks and regards,
    George
  16. Sokol1
    Sokol1 Member
    14Coins
  17. tirta
    tirta Member
    @ Sokol1,
    about JDM/JD2, which is the easiest to build?
    and since I plan to use hall sensor,
    is it better to use noalone version?
    and can I use two single sided pcb instead of double sided if I can not find it?
    please advise.
    @willynovi,
    thanks for designing this usb controller,
    I think I am going to try to make it. :D
    @Andy,
    thanks for the translation! :D
    it really helps to read it in english.
  18. GeorgeBoles
    GeorgeBoles Member
    4Coins
    Sokol,
    Thanks for the assistance.
    Unfortunately I have tried that site before.
    There is no link to a bootloader .hex.
    I tried to REGISTER so I could see what WilliNovi wrote, but the web pages are do not load up completely and I cannot get in.
    Is the bootloader .hex file available anywhere else? I think I need it if I want to program the PIC in circuit (ICSP), don't I?
    Regards and thanks,
    George.
  19. Sokol1
    Sokol1 Member
    14Coins
  20. GeorgeBoles
    GeorgeBoles Member
    4Coins
    Thanks, Sokol.
    I downloaded the files, successfully I think, from sendspace.
    I will check them out soon.
    Regards,
    George.
