Wind, 3dof and a few questions
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by notcloud, Jan 23, 2023.
Tags:
  1. notcloud
    notcloud New Member
    shop manager
    Near to, Canterbury, Kent, UK
    58Coins
    Hi, I was wondering about adding in wind control to my yet to be built setup.
    Is it best to add a second arduino and an IBT2, or can one arduino stand to add in a fourth control with 4x IBT2`s without losing control resolution (gets jerky)?
    I have searched on here can`t really nail it down.
    @noorbeast, I`ve looked at the first page of your build, it seems awesome. Did the 40kg pair of servos help a lot, or would I be better to add the fourth IBT and a larger motor for it instead of a pair of servo`s?
    Currently I`m at the design and gather stage. I have four IBT2`s two decent wheelchair motors, one wiper motor, one shop sliding door motor with associated belts and pulleys, another pair of large geared motors off of an industrial screen printing enlarger.
    I accidently ordered 3x 60 degree hall effect rotarys, didn`t notice until they arrived. Ahh well I`ll make them work
  2. Historiker
    Michigan USA
    9,208Coins
    Hi Notcloud, you will need a separate Arduino/Motor driver for wind. The wind arduino would use a different sketch from the one running your motion.
  3. notcloud
    notcloud New Member
    shop manager
    58Coins
    But can I stream the two sketches into one sketch, or is the Arduino not powerful enough? Whilst I'm not the best coder in in the world, I am a coder nonetheless
  4. Gadget999
    11,941Coins
    I suggest 2 arduinos
    3 motors on one board
    A wind sketch on the 2nd board
    You will need to create a custom program if you want a single arduino to do both jobs
    Simhub can program an arduino/nano automatically to drive a wind fan
  5. notcloud
    notcloud New Member
    shop manager
    58Coins
    Can an single Arduino drive a 6dof? If so the I bet ad
    Bother. Wasn't wearing glasses and on phone. I may have closed the thread. Help admins!!
    150,578Coins
    +11,017 / 55 / -2
    Ultimately I redesigned my rig and did away with the servos, I would suggest a bigger motor for dedicated axis, more powerful at similar cost.
  7. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    I found this guy to be really helpful when setting up a wind simulation.
  8. notcloud
    notcloud New Member
    shop manager
    58Coins
    Thanks for the link and the input guys. For simplicity two arduinos looks better. As the nano is according to what I read, identical to the Uno in connections but in a dil30 format, I may go down that route as they would at least take up less room, and are easier to implement into a custom PCB. Talking of which I've just ordered a small usb CNC router which should be able to create PCB's. Plus side it has a laser engraver so I could use photo resist and possibly engrave it then etch the board traditionally. This looks like it could be a pricey hobby, cos I bet once I build my first one, a better 2nd, 3rd will no doubt happen.
  9. notcloud
    notcloud New Member
    shop manager
    58Coins
    Has anyone tried the Arduino zero? More powerful than an Uno, pricier too
  10. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
    With 1 arduino uno you can drive 2 fans perfectly
