Which VR headset ?
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Gadget999, Apr 3, 2020.
  1. Gadget999
    12,307Coins
    I am about to buy my first VR headset
    Pretty confused about what to buy tbh
    Something i am unsure about is motion cancellation, I guess it stops the image jumping about as you move on the sim
    So which model do i get ?
    I am quite liking the FOVE system with its built in eye tracker
    Any suggestions greatly appreciated
    154,412Coins
    +11,181 / 57 / -2
    It depends a bit on your budget and personal VR priorities.
    FOVE is a dev kit not really a consumer VR HMD.
    The Rift S is a pretty good budget PC HMD. No motion cancellation.
    The Oculus Quest with Link cable can do stand alone and PC VR, but it has a lower FPS and can have some artifacts, it is also front heavy and in my view needs the Vive DAS mod and new face cushion to be comfortable. No motion cancellation.
    The Reverb has good resolution but not great comfort and has hard lines in peripheral edges. The controller tracking is not great, but that is not an issue for a sim rig. No motion cancellation.
    The Index is about the pinnacle of Gen 1 PCVR, with great tracking, including motion cancellation, slight increase in Gen 1 FOV, good comfort, great audio and controllers, but it is pretty expensive and not available in many countries.
    Pimax HMDs have the best FOV, good clarity but some small distortion, there is the new comfort kit and it includes motion cancellation in the PiTool software. I use a 5k+ with DAS mod on my rig, as the Index is not available in Australia. Pimax is well known for over promising and under delivering after long delays, and also needs a lot more tweaking. I do not consider Pimax a great all round HMD, as it takes too many individual tweaks to get the best out of it, but it is pretty good for a sim rig when it comes to FOV and can be dialed in for a limited number of games. Pimax is also expensive.
  3. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,767Coins
    Hi Gadget
    I have the Pimax 5k+ and can say the motion cancellation works really great with a Vive tracker. That will be an important point if you will have great movements. The headset is good - when its working....
    :grin
    Wickie
  4. Gadget999
    12,307Coins
    Is motion cancelling something that is unique to each make/model it is it cross platform
    154,412Coins
    +11,181 / 57 / -2
  6. Gadget999
    12,307Coins
    Is the motion cancellation something that works with any vr headset, or is it different for each rype ?
    154,412Coins
    +11,181 / 57 / -2
    154,412Coins
    +11,181 / 57 / -2
  9. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    I own my MR+,and feel good
  10. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Not sure it is sold anymore, more chances on second hand market, the samsung odyssey + works great, very good screen door effect removal system. Probably the best bang for buck if you have a large IPD. Entry level price for mid level perf
  11. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    MR+ Rift s may be the middle value product,
  12. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    what is MR+?
  13. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    sumsang MR+,china all call it
  14. noorbeast
    154,412Coins
    +11,181 / 57 / -2
    Is that the same as the Sumsung Odyssey+?
  15. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    For me, it's the HP Reverb G2 that has me the most excited for racing and flight sims. Can't wait for it's release next month, hope it's as good as the previewers are saying!
  16. physke
    physke New Member
    IT & Electronics Engineer
    Tauranga, New Zealand
    192Coins
    I started with the Rift S then changed to the Reverb after about 8 months and never looked back. The clarity is so much better, but the software setup with Windows, DCS and Steam is not as easy as with Oculus. It wasn't comfortable to wear at first, but with a few adjustments, it's fine now.
  17. Lesmore222
    Lesmore222 Member
    205Coins
    How about the heat these put off ? Have any of the latest models fixed this problem?
  18. physke
    physke New Member
    192Coins
    Haven't had any issues with that, however the room it's in doesn't get much warmer than 20C, so could be an issue in warmer climates. Don't know how they compare to earlier models as the Rift S was my first.
  19. Lesmore222
    Lesmore222 Member
    205Coins
    Wow thanks for the information. The thing that has always kept me away from VR was people complaining they were hot to wear which was a real negative for me. Might be time to take a second look.
  20. Gadget999
    12,307Coins
    I ended up buying a FOVE headset
    quite a powerful headset with good resolution and frame rate
    VR makes me feel sick so i have not used it much to be honest - my son loves it and explains the depth of view helps with driving games. You are always faster with VR
