which one recommended cheap /middle 3 d printer for print nylon
Discussion in '3D Printing' started by misoswan, Sep 22, 2018.
  1. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hi all
    which one recommended cheap /middle 3 d printer for print nylon?
    thanks
  2. lysa elec
    lysa elec LYSA ELEC
    - 56Coins
    hello
    very difficolt for the nylon with fefomation anr adherence with table
  3. David hatton
    David hatton New Member
    Engineer
    Scotland
    431Coins
    Pursa m3 lists lists nylon as suitable filiment not sure of others
    I have just recieved my mk3 kit not started the build so couldnt garantee it works
  4. Thanos
    Electronics Engineer
    United States
    2,830Coins
    I printed nylon with no issues on my Ultimaker3 extended. Could not use dissolvable supports though, i hope i can use the new Breakway material I'm waiting to receive.
  5. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Motion platform, 6DOF
    One with a decent heated bed and one that can get to 280 ish degree c
    Yes most Nylon filaments print at 250 but i've tried some myself and it worked so much better at 270/280'c
    Also don't try to print it onto those adhesion stickers/films.. Makes it impossible to remove!. almost broke my heated bed in half :D
  6. lysa elec
    lysa elec LYSA ELEC
    - 56Coins
    with the nylon the is a proble with temperature
    it is not easy
  7. ericRacer
    ericRacer You get old because you stop playing ! Gold Contributor
    Pilot
    Canada, Quebec
    949Coins
    Hi, i am a prusa mk3s , what temperature setting do you use for the bed ?
    thanks
  8. vitor brzozkowski
    vitor brzozkowski New Member
    Brazil, Rio Grande do Sul
    56Coins
    I have ender 3 despite being very good for abs and pla, I can't print with nylon or glue on the bed
  9. Dan Aitcheson
    Dan Aitcheson Member
    New Zealand
    - 3Coins
    I have an Ender 3 pro and print some parts with nylon with an upgraded hot end. I mainly use nylon for small bushings or sliders, so nothing fancy shape wise - I don’t know how it would handle complex geometry with nylon
  10. vitor brzozkowski
    56Coins
    do you use the hot end all metal? @Dan Aitcheson
  11. Dan Aitcheson
    New Zealand
    - 3Coins
    Yes. I did use it with the standard hot end and some better PTFE tube and the coolest print temp I could get away with (255deg) and it worked for a few prints but I kept having to trim the melted PTFE tube after a print. I was lucky not to get jamming but that is not the norm
  12. lysa elec
    lysa elec LYSA ELEC
    - 56Coins
    i have lots of probleme this nylon this ultimaker 2
  13. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Every printer has a hard time with nylon
  14. lysa elec
    lysa elec LYSA ELEC
    - 56Coins
    the nylon move on the plane whith deformation
  15. lysa elec
    lysa elec LYSA ELEC
    - 56Coins
    i have problem with the plane and reformations
  16. stanley johnson
    stanley johnson Active Member
    Diesel tech
    Nashville
    82Coins
    Focos
