    Buy Download Package Now!
Which Code for Arduino and Sabertooth
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Sam Neall, Jan 6, 2020.
  1. Sam Neall
    Sam Neall New Member
    190Coins
    I found two different tutorials for connecting an Arduino and sabertooth driver and running them through SMC 3. https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-w-softstart.9277/
    https://www.xsimulator.net/community/threads/arduino-sabertooth.5571/
    One says to use the 5v from the sabertooth the power the pots and to use pin 8 on the Arduino while the other one says to use pin 13 on the Arduino and power the pots from the Arduino. Each also has different code. Which one should I use?
  2. Ads Master
    Ads Master
    103,530Coins
  4. Sam Neall
    190Coins
