Where to begin, literally!
Discussion in 'New users start here - FAQ' started by smarterhometheater, Dec 7, 2010.
  1. smarterhometheater
    smarterhometheater New Member
    Chicago, IL United States
    I've got the construction background, and am planning my 3DOF simulator. I can handle all of the hardware construction but I am totally lost when it comes to electronics. I see H-Bridges, Moffsets, Pololu Motor Drivers, and it all makes my head spin!
    I've been thru the wiki, but there are so many options and even that seems technical for a novice like me. Is there a step by step that I am missing that says something like.. ok, load x-sim 2 on your computer, use a RS232 cable and connect to the Pololu VNH2SP30 Motor Driver Carrier MD01B , but use 3 of them since they control only one motor each...
    I mean basics! :D
    Any help would be appreciated!
    :highfive:
  2. eaorobbie
    20,465Coins
    Well yea 18 months ago all that information made my head spin but it slows down eventually and ya see the light X-Sim.
    If ya interested in Pololu products check out the Jrk12v12 Motor Controller, http://www.pololu.com/catalog/product/1393you can hook them via usb directly to X-Sim, and once programmed by the supplied Pololu software they run. My machine uses 2 units to provide motion as in 2 Jrk12v12 Controllers hooked to two 12v boat winch motors.
    Heres a vid of wiper motors in action with Jrk12v12s (Me first attempt motors plastic gearing failed) :D
    http://www.youtube.com/watch?v=n9pHEEuZ3B8
    Must do a step by sep guide for Jrk12v12's for X-Sim use, just got to find time.
  3. smarterhometheater
    Thanks for the vid and the link! So I need one driver per motor, correct?
    Geesh, this is all so overwhelming at first!
    I hope I'll get it and I'll keep asking questions! 8)
  4. eaorobbie
    20,465Coins
    Corrrect as in vid ya can see two controllers running two motors.
    There is a trex card that can control two at once but it cost more and i havent been able to test,
    or find some using it for the same purpose, Pololu designed the Jrk to be an oversize servo control card so robot builder werent restricted to using weak of the shelf rc servos in their robots.
    And questions always welcome, helps me to become a better sim builder.
  5. ferslash
    ferslash Active Member
    4,798Coins
    EAROBBIE:
    I hoppe you find the time to give us a step by step on pololu stuff i have been searching for days a diy, out of the shelf guide for a wipper joirider... and nothing, everything is too technical... please help us
    :D
    fer from mexico
