what specs are needed for H-Bridge
Discussion in 'SimTools compatible interfaces' started by stowaway, Feb 18, 2012.
  1. stowaway
    stowaway New Member
    Gold Coast - Australia
    1Coins
    I'm just looking at some cheaper options to go with my Arudino to run a winch motor.
    Whats specs do I need.. would this chinese knock off h-bridge do the trick?
    http://www.ebay.com.au/itm/10A-H-bridge ... 256cd375f8
    Specifications:
    Rated voltage: 3v-36v
    rated current: 10A
    peak current: 60A
    frequency:1K——100K
    Size: 11cm X 5.8cm
  2. bsft
    looks interesting.....
    If the ard code can be sorted....maybe.....
    Speak to the ard code guys here........
  3. stowaway
    stowaway New Member
    1Coins
    I *think* as long as those specs can handle my motors, then comunicating it with my arudino should be no problem.
    I'm pretty much just using the arudino as a programmer and serial connection at this point anyway.
  4. stowaway
    stowaway New Member
    1Coins
    this device is rated at 10amps with peak 60amps
    my winch motor runs at 25amps..
    Do you think this h-bridge will handle it if I install a computer fan ontop of the bridge?
