what cheap linear actuator to use to test SimTools?
Discussion in 'New users start here - FAQ' started by dirigible, Apr 9, 2020.
  1. dirigible
    dirigible New Member
    Ontario, Canada
    131Coins
    2DOF, SCN5
    Hi, all.
    I've built arcade cabinets and tinkered with arduino, but I'm completely new to motion sims. To get my feet wet, I'd like to buy a couple of small, inexpensive linear actuators to test out SimTools. Can someone point me in the right direction?
    Cheers!
  2. Gadget999
    11,953Coins
    use some rc servo motors !
    150,728Coins
    +11,018 / 55 / -2
    For testing I consider you would be better off using cheap RC servos to build a model, as inexpensive actuators are way too slow for motion simulation: https://www.xsimulator.net/community/faq/build-a-model-to-test-your-design-ideas.136/
    Alternatively, you can play with SimTools using a simulated simulator: https://www.xsimulator.net/community/faq/testing-simtools-without-a-simulator.171/
    You will find plenty of other helpful information in the FAQs to get you started, in particular check out the fundamentals of motion and the design section: http://www.xsimulator.net/community/faq/
    Have fun with your research and experimentation.
  4. dirigible
    Ontario, Canada
    131Coins
    2DOF, SCN5
    Excellent info--thanks! I was hoping the response would be RC servos, because I have some on hand.
