Want to buy....
Discussion in 'Marketspace - Marktplatz' started by Artistichalo, Dec 3, 2016.
  1. Artistichalo
    Artistichalo Member
    South Florida
    511Coins
    Want to buy complete seat shaker rig (2DOF) or parts to build my own.
    150,602Coins
    +11,017 / 55 / -2
    Parts list suggestions for the easiest 2DOF performance build -
    You can get motors from Canada:
    25:1s - http://www.ebay.com/itm/GEAR-MOTOR-...384?pt=LH_DefaultDomain_0&hash=item51bd392f00
    50:1s - http://www.ebay.com/itm/GEAR-MOTOR-...L-FEED-SIMULATOR-75-80RPM-50-1-/371596157992?
    2 X JRK control boards http://www.pololu.com/product/1393/
    1 X 80mm or 120mm fan to cool the JRKs.
    2 X proper size heat sinks for the main chips on the JRKs, plus some double sided thermal tape to stick them on: http://www.ebay.com/bhp/thermal-adhesive-tape?rmvSB=true
    2 X Hall effect pots: https://www.element14.com/community/search.jspa?q=6127V1A180L.5FS
    2 X correct size flexible couplings to connect Hall Sensors to motor shafts: http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=flexible coupler&rt=nc&LH_BIN=1
    Set of 4 tie rod ends to connect motor levers to seat frame: http://www.aliexpress.com/item/4pcs...ight-hand-tie-rod-end-bearing/1559309095.html
    2 X Server PSUs: http://www.xsimulator.net/community/threads/how-to-modify-a-server-power-supply-for-12v.5774/
    A race style seat, something like this or whatevere suits your taste and budget: http://www.ebay.com/itm/1PC-UNIVERS...RACING-BUCKET-SEAT-W-SLIDER-C08-/381149139701
    Old tailshaft with usable universal joint.
    Some 30mm steel tube or whatever material for the frame, some 6mm angle for motor mounts and some 6mm X 30mm flat for levers.
    Some shielded cables for wiring and some ferrite clips for all usb cables: http://www.ebay.com/sch/i.html?_odkw=ferrit clips&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xferrite clips.TRS0&_nkw=ferrite clips&_sacat=0
    Miscellaneous electrical connectors and kill switch.
    • Informative Informative x 5
