Want to buy controllercard and motorcard to wipermotors.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jandersson, Feb 15, 2009.
  1. jandersson
    jandersson New Member
    Hi!
    I want to buy the electronics to make a wipermotor simulator 2dof to work.
    What is the best setup? AVR controlleren + H-bridge? Vellerman?
    Im gonna use 2 wipermotors from Nissan Micra 88, if i can?
    Send me a PM!
    :cheers:
  2. jandersson
    someone who has a avr and h-bridge or a step by step to do the electronics?
  3. erichans
    erichans New Member
    6Coins
    Hi jandersson,
    Having built the AMC-DSMhb hardware setup by Thanos from scratch, I second what SirNoName has advised. You will never get more detailed information and instructions than you get here, PCB info, Parts Lists, circuitry, heaps of tutorial style PDF's, and lots of videos to guide you. But you must be prepared to do a lot of reading and collating all that you will require, and studying all the problems other people had, and solutions. In the end, this was one of the most satisfying projects I have ever done. It doesn't matter even if you're not too hot on electronics---with your interest, you'll learn fast, right from learning how to solder correctly, if necessary!! :clap:
    I must also mention that I went the Velleman K8055 and KT5198 route first, but as of now they are lying around doing nothing. I just couldn't get enough info and help to link everything up and get a working system, and I'm not smart enough to do it all by myself! :uups:
    Best of luck, Erich.
  4. Tommy
    Tommy New Member
    Finland, Vasa
    243Coins
    Edit: moved my questions to another more proper topic.
    BTW. jandersson, Im from Finland and speak Swedish. Maybe we could help each other out with this project.
  5. jandersson
    Tommy: Nu har jag änligen satt mig in i projektet lite och ska beställa hem alla delar. Dock så vet jag inte hur jag ska göra med beställningen då det är svårt att hitta alla delar på elfa.se.
    Har du msn så kan vi prata lite där kanske`?
  6. egoexpress
    Please consider that we wont be able to help you, if you continue to post in swedish language ;D
    Regards
