videos of motor levers and pot gears
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by bsft, Oct 29, 2013.
  1. bsft
    I thought I would add this so people can see the lever working on a motor
    and the gears on the back of a motor bolt turning the pot for feedback
    All for reference.
    • Like Like x 6
  2. StebanJigs
    StebanJigs Member
    electrician
    Edmonton, Alberta, Canada
    430Coins
    Are those Hall effect pots you are using there? If so what kind/ratings do they have?
  3. bsft
    nope, 5 k ohm 0.5 watt 3 multiturn pots , wired wound, from rs components. The gears I use allow about 1.8 turns of a 3 turn pot.
  4. StebanJigs
    StebanJigs Member
    electrician
    430Coins
    Right on, thanks for the info.
  5. Nicko321
    Nicko321 Member
    salisbury South Australia
    288Coins
    @bsft do you just use bolts and do them up real tight as motor axles or should I have purchased axles with my motors? I am trying to get all parts collected before i start to build. Judging by most photos it looks like just bolts.
    Cheers,
    Nick
  6. bsft
    Yes, the 25:1 boxes have a hollow shaft, so I tighten the F@#^&K out of a 12mm bolt in it and then add a 5mm threaded screw thorough the gearbox shaft to hold it steady in case the bolt comes loose.
  7. Nicko321
    Nicko321 Member
    288Coins
    Thanks @bsft you then drill a hole in the bolt head and directly place your pot into that. do you need loctite or anything in there? I have Hall effect pots as you have used on your builds. I have received my motors, JRK's, power supplies and pots and am currently just trying to work out the best way to actually build my rig. I will start a build thread soon, but found this thread and thought it is as good time as any to ask. Thanks for all your help.
    Nick
  8. bsft
    In the bolt head, I drill a hole into it to sit the shaft of the pot, then I tap a 3mm bolt into the hex part to hold the shaft on with a 3mm bolt. Instead of trying to drill trough a hardened steel shaft.
    Oh and I dont use hall effects anymore.
    Just 360 deg single turn wire wound pots
  9. Nicko321
    Nicko321 Member
    288Coins
    Are the hall effects still ok? @bsft I must have missed the memo that had changed
  10. bsft
    Yes Hall effects are fine, but mine were 180 deg and I needed more range.
    Hence using pots now
  11. Bobsyouruncle187
    Bobsyouruncle187 New Member
    71Coins
    2DOF, DC motor, AC motor, SCN6
    Thank you for this @bsft!
  12. Agosky
    Agosky New Member SimAxe Beta Tester Gold Contributor
    Finland
    307Coins
    How much lever movement in degrees is ok, in your experience @bsft ?
    I'm thinking about linear movement speed, which ofc reduces when lever is not at 90 degrees to connecting rod. Is this "variable speed" noticeable at all?
  13. eaorobbie
    20,464Coins
    Anything past 90 deg off movement is very noticeable as the sim moves very proportionally in the middle 90 deg and seems to only move a very little amount over the rest , actually resulting in massive losses of motion in those quadrants , as in the levers moving another 45 degs for maybe 1/2 a deg more movement in the actual chair.
    I use 30 deg connecting rods with about 79 deg set , 39 deg up and 39 deg down. On 65mm c/c levers. so linear its 80mm movement and it deviates 3mm out of line, not noticeable at all. Plus test on the Jrks to make 80mm of movement in under 0.1sec, so super quick.
    • Informative Informative x 3
