Using a Steering Gear From a Car for Gear Reduction
Discussion in 'New users start here - FAQ' started by Ben V, May 24, 2015.
  1. Ben V
    Ben V Member
    Alberta, Canada
    181Coins
    Hello all,
    I'm currently in the process of doing some research and prototyping on building my first motion simulator (2DOF Seat Mover). I'm considering using a manual steering gear from a car for power transfer between the motor and seat frame.
    The steering gear struck me as a great way to get an inexpensive ball-screw assembly that is all assembled, ready to be bolted in, and designed for fairly high mechanical loads.
    I currently have a Superwinch LT2000 with a 12V PM DC motor that I'm using for testing purposes. I measured 3.5 Nm of output torque at stall, and a free speed of 4420 rpm from this motor.
    Specifications I've found for some manual steering gears have been in the range of 25:1 gear reduction. If I modify the pitman arm to get 50 mm center to center, I figure that will give me about 1750 N or 179 kg of output force at stall speed (ignoring mechanical losses through the steering gear).
    Any thoughts on the feasibility of this kind of setup?
  2. Ben V
    Ben V Member
    Alberta, Canada
    181Coins
    I've decided to go ahead and try prototyping this approach to see how well it works. Check out my build thread here to follow along.
