Using a Raspberry Pi for controlling actuators
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Dewald, Nov 13, 2016.
  1. Dewald
    Dewald New Member
    South Africa
    145Coins
    Good day,
    I am new to programming and the use of a raspberry pi. I have a great interest in racing and would like to build my own racing simulator. I would like to know how does a raspberry pi communicate with the xsimulator software. I would like to use telescopic actuators to induce the motions and would like to know how to get all the software and hardware to work together.
    Kind regards
  2. BlazinH
    16,698Coins
    The same as a microcontroller does; either by serial or UDP.
  3. Dewald
    Dewald New Member
    South Africa
    145Coins
    Oky thanks.
    Because I'm new to a raspberry, how do I access the data sent by the Game Engine in my raspberry?
  4. BlazinH
    16,698Coins
  5. Dewald
    Dewald New Member
    South Africa
    145Coins
    If I send data via UDP, what must I code the Pi with in order to see what and how the data was received?
  6. BlazinH
    16,698Coins
    I don't know. I don't use one and neither does anyone else here for motion (as of now at least). Since you are new to programming I suggest you take a look at what you can get from this site and go that route instead.
    https://www.xsimulator.net/community/forums/simtools-compatible-interfaces.25/
  7. Dewald
    Dewald New Member
    South Africa
    145Coins
  8. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    Hello ,
    What type of actuator?
    DIY?
    Motor DC or AC ?
    Raspberry Pi = Output PWM 3.3v?
    What power interface do you use?
    Bonjour ,
    Quel type d'actionneur ?
    DIY?
    Moteur DC ou AC ?
    Raspberry Pi = Output PWM 3.3v ?
    Quelle interface de puissance comptes-tu utiliser ?
  9. BlazinH
    16,698Coins
    One issue with the R. Pi is it doesn't have built in ADC's so it can't read pots without adding external ADC's. I don't imagine it has PWM outputs either. That said, it may work well for reading encoders and you could use Sabertooth controllers with it. :)
  10. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    Maybe a motion controller is a little ambitious for first programming project. Start by learning to open data ports and receiving data first. Maybe turn on an led. Next try to understand something like the code in the smc controller. If you understand that you should be able to start porting the concepts you've learned to raspberry pi
  11. Dewald
    Dewald New Member
    South Africa
    145Coins
    Thank you, I will read up about it!!
  12. Dewald
    Dewald New Member
    South Africa
    145Coins
    I have done some small programming like that, just never used live input data and also never used serial or UDP and don't know how yet.
  13. Dewald
    Dewald New Member
    South Africa
    145Coins
    Want to use SMC 117N Electric Linear Actuator, 24V dc, 200mm stroke actuator
    It is a DIY project I want to start,
    Want to use DC as far as possible,
    Yes it's 3.3V
    Not sure what to use yet
  14. SeatTime
    https://www.xsimulator.net/community/faq/
  15. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    If you want to install Simtool on Raspberry, this is impossible because it's developed in .net language. Maybe you can try to install with "wine", but in my opinion it doesn't works.
    Anyway you can send data from Simtool to Rasp with USB (serial), or UDP. When this communication works, you can write your custom python script to move actuators.
