USB Adapter
Discussion in 'SimTools compatible interfaces' started by kopex, Oct 16, 2010.
  1. kopex
    kopex New Member
    Today i finished my AMC Board and tried to connect it to the PC with an USB Adapter.
    When ein connect it, i get a short circuit an my Power Supply shuts off.
    I cannot find the problem on the board.... whats wrong?
  2. egoexpress
    Hold the pcb in between a strong lightsource and your eyes, so that the light shines through the pcb, and then check your solderjob for shortcuts.
    If you have a high res camera, post a picture of your pcb, while the light shines through it.
    regards
  3. Frakk
    Frakk Active Member
    328Coins
    Which power supply is shutting off?
    USB power supply (PC) or the 12V power supply?
  4. kopex
    kopex New Member
    i checked everything 5 times.... there is no shortcut...
    The PCB Powersupply shuts of. Now i changed the Source and it is working. But is only works, if i plug in the power AFTER plug in the USB Adapter. In the other case, the LM2940 does not start?
    Anyway.... When i use ponyprog2000 and i try to read security settings, then the red LED flashes, but i get the Error that device is missing.
    After 1000000 errors it works. After that i tried ti write, but the same here. Again after 10000 errors i could write the settings. But the writing procedure took about 10 Sekonds. I dont know if this is normal.
    Now i am flashing the firmware and the red led lights on, but i cant see any progress?
    I am waiting for 10 minutes now, but nothing changes in the status. (when i was reading settings, the status also was not changing. It was 0% and then just finished (after 10 seconds) )
    is that normal?
  5. egoexpress
    No ;P
    Make sure that you enable the serial printer option for the USB adapter.
    What crystal do you use? Some Atmega', like the one I used for example, dont work with 24kHz overclocking. Try a 18 or 22kHz crystal instead to see if it resolves the device missing problem.
    It did the trick for my AMC.
    Btw, I did use sockets for all active parts (crystals, ICs, voltage reg.), so that I am able to replace them easily for troubleshooting.
    regards
  6. kopex
    kopex New Member
    after a lot of errors and retries it works with 22MHz.
    Reading and Writing security settings works fine. Flashing the firmware takes about 1 hour (not finished yet). It seems to be VERY SLOW.
