Question Update a 2dof system. A third wiper motor is worth?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by EduardoMoreira, Jun 24, 2020.
  1. EduardoMoreira
    EduardoMoreira Member
    113Coins
    I was thinking of doing an update on my 2dof system, but changing the engines would require a modification in the structure. My platform follows the pattern of two wiper engines in front. If I put a third engine in the back will I have a significant increase in some effects or will it not make a difference? Thank you
    153,866Coins
    +11,152 / 57 / -2
    If you are thinking of adding a third motor I would suggest it would best be used for traction loss, if you use your rig primarily for race games.
  3. EduardoMoreira
    113Coins
    Thanks noorbeast
