UnoJoy gamepad
Discussion in 'Electronic and hardware generally' started by Dusko Dogandzic, Oct 16, 2015.
  1. Dusko Dogandzic
    Dusko Dogandzic New Member
    456Coins
  2. tombo
    tombo Active Member
    2,442Coins
    DC motor, Arduino
    I've tried it. It works very well.
    There are better options avalible, but if the specs are right you can use it. I also flashed the arduino back to use it as arduino. It worked also and was very easy.
  3. Dusko Dogandzic
    456Coins
    well my idea is to enable 3 axis and use it as a pedals for clutch/brake/accel arduino is pretty cheep 2e from china potentiometers cost more then arduino. For what did u use it? @tombo
  4. ferslash
    ferslash Active Member
    4,798Coins
    i did what you are trying, one tip to help you not get insane... when you test your pots connected to the analog ports of arduino, always connect all the 3 or 4 pots you will use, if you test connecting only one pot, you will move all the axis at once and it will drive you crazy... i asked for help at their forum and nobody answered.... so those are my two cents.
    best regards
  5. tombo
    tombo Active Member
    2,442Coins
    DC motor, Arduino
    I only used it for testing purpose of Diy Hardware. The resolution you can get is not very good.
    Better get a Teensy but will cost more.
  6. Dusko Dogandzic
    456Coins
    resolution wise i think its not that important because my current one logitech momo has only 8 bit resolution which is 0-255 arduino can handle up to 0-1023. i think its better to invest in higher quality pots then in teensy (tho i like it and i think i will get one but for some other project)
    some reference:
    logitech momo: 8 bit
    logitech g25: 8 bit
    fanatec v2 clubsport: 10 bit
    fanatec v3 clubsport: 12 bit
