Tutorial on using Monster Moto
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Roy, Mar 28, 2015.
  1. Roy
    Roy Member
    Marine Engineer
    Saint John, New Brunswick, Canada
    1,142Coins
  2. eaorobbie
    20,467Coins
    Some good info but it has been found that the heat and the high amps can affect the Ard, remember our sims can push these to their limits same as the other type of boards, plus high amp feedback can kill usb ports and anything connected to them, some use opti couplers so no power can be feed back to the Ard in case of driver failure or motor lockups. But saying this I have not heard of one having this issue in ages.
    But some good info , well spotted.
  3. RacingMat
    21,023Coins
    Thanks for sharing: indeed newbies will find useful information there :)
  4. Roy
    Roy Member
    Marine Engineer
    1,142Coins
    I thought the MM's purpose was to protect the Ard. With heat-sinks added to the MM from what I've read here and other places protects the MM from burning up under high loads....such as you guys have put them in. The MM's are such a low price I was thinking when I get to build the Sim for my friend that I will probley set it up like Pit suggested here. http://www.xsimulator.net/community...cts-as-a-single-motor-driver-more-power.5482/
  5. dberg1
    dberg1 Member
    refrigeration pipefitter
    west of chicago,il
    150Coins
    Great info, thank you.
