Turbulence
Discussion in 'Flight Simulator 2020 - FS2020' started by Keith, Oct 5, 2022.
  1. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    118Coins
    Hey guys. Can anyone feel turbulence with there setups? I have being playing around with the heave numbers but I can't really feel much. I do feel alot while landing or on runways though
  2. SeatTime
    28,370Coins
    What sim are you playing? Some sims like DCS don't have any real turbulence.
  3. Keith
    Keith Active Member
    Electrician
    118Coins
    Fs2020. I just tried some windy landing challenges and I think I could feel the turbulence a bit. Need to do some more tweaking I think
  4. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,608Coins
    Hi Keith,
    I was also searching for the perfect feeling of turbulece for a looong time. I tested so many settings in mover-interface, but allways when I increased some gain to feel turbulence, the rest of the simulation was much too agresive.
    BUT later I found a workaround for this: I use heave for the feeling of turbulence, increase the input gain a lot and then I apply a crash-filter to cut off the too agresive movements and make everything smooth. I can say, now the feeling of turbulence and really flying is sooooo amazing!
    But in my case, I have a 6DOF - so can use heave.
    If you have a 3 DOF with a central pivot point you have to try a different DOF.
    I hope this information will help you to improve your feeling of turbulence.
    Wickie
  5. SeatTime
    28,370Coins
    Having tried most of the available MSFS heave plug-ins for FlyPt, SRS and Simtools. Simtools works the best IMO. You can add heave DOF to a seat mover, just keep the heave movements small, so that it does not turn into a surge.
  6. Keith
    Keith Active Member
    Electrician
    118Coins
    Thanks for the responses guys. I am using a 6dof now. so I will definitely give Peter's method a try!
  7. sallerding
    sallerding Member
    Perth, Western Australia
    326Coins
    Hi Peter are you able to share your profile on flypt ? I would love to see your settings for turbulence. But also how you may have treated other treatments like landing gear turbulence, flaps and speedbrake. I understand emalp and emahp, but what are you referring to as a crash filter??. Thx for any help.
