Question Travel limit settings
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by James Robbie, Oct 10, 2018.
  1. James Robbie
    James Robbie Active Member
    IT Specialist
    New Zealand
    538Coins
    Hello all,
    Been a while since i have posted as its been about 6 months since i have seriously worked on my 2DOF motion project. I have got a new big wind of motivation and i have a couple questions regarding travel limits:
    My system - arduino/MM/wiper motor 2DOF
    1. Can you limit axis travel via settings/software?
    2. If there is more than one option for question one, what is the best way to limit the travel?
    I have removed the stops in my POT's. I don't want to introduce clipping where the system shuts down and i don't want to reduce power. Initially I just want to keep my motion limited instead of going to full extent of POTs.
    Thanks in advance
    153,131Coins
    +11,117 / 56 / -2
    There is an Axis Limiting tab in the Axis Assignment section of Game Engine.
  3. James Robbie
    IT Specialist
    New Zealand
    538Coins
    Is that based on percentage of the existing travel?
    153,131Coins
    +11,117 / 56 / -2
    Yes it is.
  5. James Robbie
    IT Specialist
    New Zealand
    538Coins
    Thank you very much. I feel embarrased and like an idiot because it was so obvious BUT i am now an idiot with an answer
  6. ne02005
    ne02005 Member
    Argentina
    105Coins
    Hi, Yes I´m using the limit axis option too, My setting is about 50%, if I leave on 0% the simulator is very dangerous... I felt by side... ;)
