The cheapest method to use tronic amc with usb
Discussion in 'SimTools compatible interfaces' started by dj dicksy, Mar 26, 2011.
  1. dj dicksy
    dj dicksy New Member
    Romania/Bacau
    340Coins
    This is what i found on the internet.
    http://seriousrobotics.wordpress.com/20 ... r-about-5/
    I tried this method with a ma-8260 data cable and it works very well.I think it will work with this type of cablu.If this has been discussed before,mea culpa.If not,good luck to those who are interested in this subject.
  2. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    Thanks for the tip :thbup:
  3. bsft
    From what I can tell it modifies and RS485 conveter, that is for actuators only. Is that right, or am I reading it wrong?
    Also, what circuit board does it hook up to and does it control motors?
    By the way, I can buy an USB to RS485 cable locally for about $15. If there is a dc motor controller board that it can connect to , this would be handy to know.
    Cheers.
  4. valy_budascu
    valy_budascu New Member
    Romania, DB
    219Coins
    Hi dicksy,
    I'm glad to see another romanian around here. I was thincking I'm the only one.
    Good luck in your projects!
  5. Frakk
    Frakk Active Member
    328Coins
    This is not RS485. It outputs TTL UART communications.
    For this much money don't expect anything. It is a very cheap chinese converter with chip-on-board, noone knows what sort of silicon they put under that black epoxy.
    Personally, I cannot afford to buy cheap stuff like this. The $10 I save on money will be thrown out the window when I waste my time, trying to troubleshoot the problems it can cause in the circuit...
    I advise everyone to avoid this and save the headache. Spend the extra $10 and don't worry about it in the future.
  6. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    :tape: no comment.
