Targas 2DOF Motion Sim Project
Discussion in 'DIY Motion Simulator Projects' started by crxTarga, Feb 11, 2010.
  1. crxTarga
    crxTarga New Member
    IT-Consultant
    Tübingen
    320Coins
    I am a totally newby to motion sims, but I have read all your articles and now I have this I want it, too feeling.
    I hope this is not too tough for my first adventure trip into electronics.
    Step 1:
    My ordering for the parts for the AVR Motion Board and the Dual Motor H Bridge is prepared. Thanos, Sirnonames, Christians and Michaels DIY Motion Sim are the threads for my orientation now.
    But this will be the hardest part for me, to solder this boards without errors and to understand the eletronic background.
    Step 2: NEED ADVICE!
    I found these motors from a e-scooter, located at a dealer near my home town.
    Motor für E-Scooter 1250031 24V 120Watt http://www.ts-audio.biz/tsshop2/WGS/6872/PRD/ETT1250154/Motor_fuer_E-Scooter_1250031_24V_120Watt.htm
    Elektro-Motor MY-1016, 24V=, 250W http://www.ts-audio.biz/tsshop3/WGS/6872/PRD/ETT1250171/Elektro-Motor_MY-1016_24V=_250W.htm
    They seem to be very compact, yet very powerful.
    Is the voltage 24V a problem? Or the max Ampere 13,7A (8A)?
    There are only two wires coming out of the motor chassis. Will the mass cable need to be lead out?
    Step 3:
    Building the Motion Simulator together. I will start this step, if step 1 & 2 are solved.
    Wish me luck, now I must read further articles from Thanos and co.
  2. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    Hello Targa. Me too had Thanos AMC as my first electronic soldering project. Now it is done, and I am ready to start the building of a sim. My advice is to take your time, and make no hurry. its not a bad idea to check solderings very carefully and many times if you get problems, double check your order of parts, and its a goo idea to have extra parts of some sensitive components etc. mosfets and ic`s. Another advice is to read once again all the topics about it if you run into problems. But this forum gives you a lot of help i can ashure you!!! What kind of sim-rig do you plan. Thanos H-bridge is build for 5-50 volts, but others can give good advice on this questions! :thbup:
    God luck!
    Fred
  3. crxTarga
    crxTarga New Member
    IT-Consultant
    Tübingen
    320Coins
    Thanks for your tips, Fred.
    Actually there's no reason to hurry, so I'm going to order, build, solder, plan this project very carefully.
    For now, I try to gather as much information I can. This forum is full of it. Maybe I need one or two more weeks of further investigation.
    If I took these motors, what would I need for a power supply? Could this be done with a PC Power supply?
  4. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    Cool, aus Tübingen - des isch fei gar net mal so weit weg von Augschburg ;D !
    Viel Spaß hier - bin schon auf Bilder & Co. gespannt...
  5. crxTarga
    crxTarga New Member
    IT-Consultant
    Tübingen
    320Coins
    Hey,
    ja, von dir hab ich auch schon viel gelesen, Chris. Und dass Augsburg nicht weit weg ist, hab i au scho festgschtellt.
    Bilder von meinem Projekt hab ich noch keine. Aber vielleicht zeig ich Euch mal den aktuellen Stand vor der SIM:
    So sieht mein Arbeitsplatz aus:
    ATI 5770 Eyefinity mit 3 mal 22 Lenovo Monitoren
  6. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Seh grad das du vielleicht 10km von mir entfernt wohnst. Ich bin den SCN5 Weg gegangen, und mein Nachbar besteückt grad die Platinen für seine Schweibenwischer Kontroller. Vielleicht kann man da nen Stammtisch machen und sich gegenseitig helfen...
