Tactile Feedback / Shaker / Audio card suggestion needed
Discussion in 'Off Topic - All other stuff here' started by hannibal, Oct 26, 2018.
  1. hannibal
    hannibal Active Member
    4,489Coins
    i am interested in using bass shakers with Gamevibe.
    but my motherboard has limited expansion
    i have a motherboard that has 2 PCIe graphics slot, 1 PCIe 1x slot.
    It has onboard audio. it is a MSI Z370M carbon gaming pr AC.
    because i use this for Virtual Reality, i have used up the PCIe 1x slot to accomodate additional sensors for my oculus rift.
    For tactile feedback, i have two amplifiers pushing shakers.
    Do you guys think i need an additional sound card, or usb audio adapter... or i should be ok with the onboard sound to drive the two amps thru gameVibe?
    145,124Coins
    +10,778 / 52 / -2
    You can use USB soundcards, they are pretty cheap and convenient.
  3. CQeNS
    CQeNS New Member
    50Coins
    I use 2 transducers configured for front/rear, 1 2-channel amp, and 2 cheap USB sound cards, one per channel/transducer
  4. paulopsx2
    paulopsx2 Active Member
    brasil
    616Coins
    im using 1 out from motherboard, another from usb sound cars. works perfect
  5. hannibal
    4,489Coins
    thanks everyone!!! :):):) wow.. even with out motion, i can still play with just audio devices... crazy!
    what it comes down to is that i have
    a 1x) crown 1500W amp
    1x) buttkicker LFE
    1x) dayton SA70
    1x) arua shaker
    1x) Behringer U-Control USB audio adapter that has 2 RCA outputs...
    and onboard motherboard sound
    for the most part i just send low pass audio to all devices (yes, it sux when someone talks on teamspeak, i get a message)
    but i like to take the audio a step further...
    do you guys thing GameVibe can separate effects in to 3 independent feedback?
    i like to implement a front right shaker, front left shaker, and a center back..
    i know i will need a shaker.. will i need a third USB audio adapter? i also read about simVibe which is a whole other company, i hope Gamevibe can handle my desired setup of 3 independant shakers
    145,124Coins
    +10,778 / 52 / -2
    Yes Game Vibe can do that and yes you will need a sound card for each independently controlled transducer.
  7. hannibal
    4,489Coins
    thanks for reply! @noorbeast :thumbs
    out of curiousity, what USB sound card to you guys use?
  8. CQeNS
    CQeNS New Member
    50Coins
    I purchased mine on amazon, they were both generic 2.1 USB sound cards. They are cheaper on ebay if you are willing to wait.
