Tacho by Elektronikjack - problem
Discussion in 'SimTools compatible interfaces' started by marcin, Dec 14, 2010.
  1. marcin
    marcin New Member
    Hi I made a PCB (fixed 2 errors on PCB - short circuit) and programed Atmega32 but i have problem with start serial communicate.
    I set fusebits in ponyprog:
    checked =0 unchecked=1
    CKOPT bit=0; bootsz1=0; bootsz0=0; bootrst=1; sut1=1;sut0=1; cksel3=1; cksel2=1; cksel1=1; cksel3=0
    I've maed a serial cable rx and tx crossed (pins 2 and 3) and gnd on 5 when i turn on hyperterminal nothing happend.
    On board I can erase/read and write Atmega. please help me with my problem. How I can test boot AVR or what change in fusebits?
  2. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    cable problem maybe..
  3. marcin
    marcin New Member
    Hi Kubing what You mean cable problem'? i've got schemat rsr232 and have 3 lines RX,TX and GND the rx and tx i crossed that is good connection. Do You know what should hyper terminal show when connection is estabilsh?
