struggling with the plugin nolimits 2
Discussion in 'Off Topic - All other stuff here' started by f1iceman, Dec 29, 2015.
  1. f1iceman
    857Coins
    I have the non steam version of nolimits 2 and im struggling to change the path on the short cut i add the telemetry part and it fails saying its not there ? so won't let me change it to add it.
    any help getting it running :)
    one issue i can think of is i installed the game to another drive but plugin was fine it says going in the pluging window.
    i then put the patch into the folder nolimits 2 on drive i installed too.
  2. f1iceman
    857Coins
    the version is nolimits 2 standard 2.2.3.0
    150,740Coins
    +11,018 / 55 / -2
  4. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    I can confirm that it works on 2.2.3.0
    Create the shortcut in the 64bit folder on the drive it is on then drag it to the desktop if that wasn't how you did it.
  5. f1iceman
    857Coins
    hi i draged it to desktop n created shortcut but did not create it first in the folder then move it.
    will try it that way.
  6. f1iceman
    857Coins
    all sorted just downloaded the plugin again deleted all the old stuff and reinstalled everything again and its finally worked :)
