Question Starting from zero as hobby. requesting guide
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Ahmed Hasan, May 10, 2021.
Tags:
  1. Ahmed Hasan
    Ahmed Hasan New Member
    89Coins
    Hello, i am patinate about cars and racing, used to live in Europe but now i am in Iraq, no tracks here, so i decided to build motion sim by myself, don't want to buy, want to enjoy making it myself.. i ordered G29 wheel with gear and Oculus quest 2 for VR..
    now, i need to know few things,
    is there a way to build the rig without microchips and coding? i mean is there some motor that can be directly attached to USB and get controlled by sim tools?
    if the above question's answer is no, then, at the moment i have one arduino UNO with kit and tiny servo motor, can i somehow now get simtools just to test that tiny motor? if it worked then i will order bigger motors and start building the rig while the motors arrive..
    if i wanted to build a 3dof rig, can you please write me a list with all the hardware that i need to order?
    if everything is fine, i will document all steps i do from ZERO till the playing game with rig fully functioning and publish to help everyone else, for free.
    i am pro 3D designer, here is my portfolio ( www.artstation.com/ahmedhasan ) , i use many different software, like 3ds max and UE4 and inventor, first i will model everything in 3D and make blueprints for everyone else for reference to return the favor,
    also, if there is actually a way to test the rig virtually somehow in 3D, would be awesome if there is article about that. ( once i saw something like so but i can't find it again )
    i think that's it, thank you.
    154,310Coins
    +11,179 / 57 / -2
    The FAQs are a useful resource for these and other common questions: https://www.xsimulator.net/community/faq/
    Some sort of controller is needed.
    Yes you can build a test model with an Arduino and servos, see the FAQs here: https://www.xsimulator.net/community/faq/build-a-model-to-test-your-design-ideas.136/
    Don't order anything until you finalise a design and get member feedback on that, it will save your time, frustration and money, use either of these tools to get your head around design Vs physics tradeoffs:
    https://www.xsimulator.net/community/faq/motion-visualizer.389/
    https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    It is possible to drive a 3D model: https://www.xsimulator.net/community/faq/how-to-animate-sketchup-3d-model-with-simtools.209/
    Or have a play with an existing virtual simulator: https://www.xsimulator.net/community/faq/simulate-a-simulator.350/
  3. Ahmed Hasan
    89Coins
    thanks that was really helpful... will start slowly on the virtual workflow and keep you updated.
