Wagnard
Star Wars Squadrons XML (STEAM version ONLY) 4.2
Star Wars Squadrons XML plugin for 4.2
  1. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    2DOF, Motion platform
    so, the plugin works using cheat engine? if i dont use cheat engine it will not move?
  2. izhangt
    - 91Coins
    In these post nobody explain what we have to do with cheat engine and the zip with pointers, can someone explain? Thx
  3. izhangt
    - 91Coins
    Hi, can u make it work? How is supposed to work with cheat engine, and the pointers with xml what is that? Nobody explain
    Thx
  4. yobuddy
    48,153Coins
    @izhangt,
    You do not need cheat engine to run the plugin, just to update it.
    (This only needs to be done when the game gets updated, as this is a memory hook plugin.)
    Take care,
  5. izhangt
    - 91Coins
    Thx my friend,
    And how I update the memory hook plug-in? Dont see any tutorial.
  6. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,453Coins
    Just posting to confirm that thanks to @Marc Fdx solution with the symbolic link, Star Wars Squadrons works with motion without disabling the internet connection or uninstalling the anti cheat software.
    Also confirm that certain ships don't work with motion as posted by @Mechromancer. I have the Steam version.
    If anyone is having difficulty in getting motion to work, check that the you have the latest Offsets file as posted by @Wagnard . I had to manually change mine, the old ones were being left over after uninstalling my old plugin.
  7. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    Thanks to EVERYBODY tinkering this path!
  8. ART FLY
    BAVARiA
    Great news - thanks for posting it!
  9. izhangt
    - 91Coins
    what simbolic link??????
  10. GWiz
    GWiz Active Member
    Dentist
    1,453Coins
    You have to make a symbolic link using the command window (Type CMD into the Windows search). I followed the instructions on @Marc Fdx post - number 38 on this thread. It tricks the game to launch the exe file instead of the launcher and so Simtools sees the exe file it is expecting for motion and the game is happy to launch without anticheat freaking out at Simtools acting all suspicious whilst also thinking that the game has been launched using the normal launcher instead of the exe alone. (I think that's how it works anyway!)
  11. izhangt
    - 91Coins
    i have the plugin working, now it doesn´t move. when u install the offset plugin u need to patch again in game manager?
  12. GWiz
    GWiz Active Member
    Dentist
    1,453Coins
    Probably your Offsets file is still the old one. I found repatching the game not to work for me and so manually changed the offsets file in Simtools to get motion working with the updated pointers. ( I can't remember the folder that the offsets file is in but if you search for "Star_Wars_Squadrons.XML" you should find it. Use the new pointers provided by @Wagnard earlier in this thread.
  13. izhangt
    - 91Coins
    It works, thx for all ur help
  14. margolle
    margolle New Member Gold Contributor
    50Coins
    hello please help me . my probleme in video
  15. paulopsx2
    paulopsx2 Active Member
    brasil
    616Coins
    ?? No vídeo here...
  16. margolle
    50Coins
    my onlly posibilty explaine my probleme
  17. margolle
    50Coins
    C:\Users\margo\AppData\Roaming\EasyAntiCheat (??????????)
    G:\Program Files (x86)\Steam\steamapps\common\STAR WARS Squadrons\EasyAntiCheat (game fille)
  18. noorbeast
    145,022Coins
    +10,776 / 52 / -2
    In the YouTube settings you likely need to make the video Public.
  19. margolle
    50Coins
    Modification video ok
  20. ART FLY
    BAVARiA
    Hi Margolle,
    I do not have too much knowledge of French and simulators.
    But I saw in your video that the percentages per axis is more than 200%.
    The greatest% age for an axis can be 120% I believe in a moment (at the same second).
    Maybe if you take like 80roll, 80pitch or 80sway and 80pitch everything is fine?
    Good night from the Baviere,
    Yours,
    ART FLY
