Some basic questions for a N00b Motion sim builder
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by elnino, Aug 15, 2018.
  1. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,537Coins
    Hi All, A long time ago I built my sim. Custom pedals, shifter etc and always intended to go to a motion setup but I have not really done anything with it in 5 years.
    I did however collect some BIG DC motors for adding motion. In reality they are probably too big but it seemed like a good idea at the time and the theory was to motion the whole existing rig (not just the chair).
    The motors I got were off of a wheelchair (I even have the controller for it too). 24v DC rated motors and should have lots of torque as they are geared but they do seem to pull a lot of amps.
    I am really not sure on what H Bridge controller to use on them (I don't think I can utilize the chair controller but it has 4 X 70A Fets for each side of the H Bridge in it!!). I have seen these '100A H Bridge' modules on Ali etc - Are they any good? Its not clear on what chips/FETS are used on them or if that is 100A total or 100A per channel. Could I bridge them like the MM modules and use one per motor?
    I have 2 X 1000W HP Server power supplies to be able to power the motion.
    The other thing I was wondering about was the physical/mechanical connections - From what I have seen, most motors are connected to the back of the seat, whereas I was thinking I would just have them effectively controlling a flat platform that I could mount the whole existing SIM on (3 point, 2DOF). Is there any reason NOT to do this?
    Really looking forward to some motion finally!
    150,776Coins
    +11,021 / 55 / -2
  3. Grigory
    Grigory Active Member Gold Contributor
    Moscow
    218Coins
    3DOF, 6DOF
    I agree, Sabertooth 2x60 is perfect for controlling large 24V motors. I have tested it with huge and current-hungry NPC-T74 motors on both 3 DOF (seat mover + traction loss) and 6DOF -- without any issue on the Sabertooth side.
