[SOLVED] Since today one winch is singing and not moving...
Discussion in 'Electronic and hardware generally' started by Pit, Dec 19, 2015.
  1. Pit
    30,476Coins
    I am using 12V winches and Motomonster. Since today one winch is singing and not correctly moving...no joke. When the winch "sings", I can move the lever by hand, there is absolutely no withstand.
    Before I have to disassemble the complete heave unit I ask you, by what this phenomena could be caused.
  2. Pit
    30,476Coins
    EDIT: one MM died. One of both MM generates only 3V.
  3. SilentChill
    20,583Coins
    Oh dear :( not good not good at all. those frkkin MM's have a lot to answer for
  4. Pit
    30,476Coins
    The failure rate is nothing. This is the first MM which failed due two years intensive testing and you know my motors are bigger than yours ;) If ever one will fail if ever this will happen one replacement is only 8$. BTW while disassembling my rig I determined many of not well tightened screws so this opportunity was more than welcome. :)
  5. Pit
    30,476Coins
    PS: I disassembled the winch, too. The winch is like new. Cheap and sturdy.
