Question SMC3 - Issues configuring motor
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by PhillyNJ, Jun 18, 2024.
  1. PhillyNJ
    PhillyNJ Member
    153Coins
    I've been working on this issue for a few days. I am able to set the my motor's settings with SMC3. The motion is smooth, however, once I sit on the rig, the motor settings are not "strong" enough to move the rig under some weight. If I increase the PWMMax, the motor can move me with no issue, but the motion is jerky. I have attached my settings.
    Any help is much appreciated.
    154,256Coins
    +11,177 / 57 / -2
    Try Fpwm at 25.
  3. PhillyNJ
    PhillyNJ Member
    153Coins
    Thank you sir. This helped a lot. I set the following
    Fpwm - 25
    PWMmin = 10
    PWMmax = 90
    PWMrev = 90
    The motion is much much better and it can handle my weight. This is a good baseline that I will further tweak!
  4. Saad7767
    Saad7767 New Member
    22Coins
    I need help how can I talk with people
    I neeeeed help
    154,256Coins
    +11,177 / 57 / -2
    You should create your own thread in an appropriate section detailing the issue, what you have tried and post pictures of all of your settings.
    Please be aware there are some post limitations for new members, to help prevent spam.
