    Buy Download Package Now!
smc3 help and sim tools
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Che Franklin, Dec 31, 2019.
Tags:
  1. Che Franklin
    Che Franklin im alot brighter than i look.. Gold Contributor
    Cape Cod Ma USA
    160Coins
    hello and thank you for all your work.
    i have just finished my build, I'm testing now ...in smc3 directions it states
    "Now slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
    If it is then that motor and feedback is wired correctly - proceed to test other motors.
    If it is moving away turn off motor power immediately (or quickly reduce PWMmax again)."
    now when i do this:
    (the pot is TEMP NOT connected to the motor /for testing perps/ and the YELLOW line moves up-down, the green line moves when I Manually Move the POT.
    What am i doing wrong Guys/Gals nouns
    and how would I know if the moto monster is bad?
    i don't see led on "DIR" when in action?
    should i?
    and should the Kp,Ki,Kd need to be more than zero?
    im using a Mega, could someone verify i did this correct
    SORRY
  2. Ads Master
    Ads Master
    103,530Coins
  4. Che Franklin
    Cape Cod Ma USA
    160Coins
  5. Che Franklin
    Cape Cod Ma USA
    160Coins
  6. Che Franklin
    Cape Cod Ma USA
    160Coins
    Do? i copy the look?
  7. Che Franklin
    Cape Cod Ma USA
    160Coins
    looking now thx you SO much\
  8. Che Franklin
    Cape Cod Ma USA
    160Coins
    how would i use wind with this code im having a HARD time
    103,530Coins
  10. Che Franklin
    Cape Cod Ma USA
    160Coins
    103,530Coins
    Game Dash is a SimTools companion app and requires a SimTools Pro license.
    Sorry I don't know about the L298n support, perhaps @SilentChill can advise.
  12. Che Franklin
    Cape Cod Ma USA
    160Coins
    i have a pro lic
  13. noorbeast
    103,530Coins
  14. noorbeast
    103,530Coins
  15. Che Franklin
    Cape Cod Ma USA
    160Coins
