Question Smc3 Digital Inputs
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Qlittles, Jan 25, 2020.
  1. Qlittles
    Qlittles Active Member
    Union City, California, USA
    226Coins
    Hello everyone, I'm in the process of upgrading from wiper motors to worm gear motors. The seller i'm buying from had already installed hall effect sensors on the motors, but his chip only outputs a digital signal for the absolute position (no analog).
    My understanding is that the arduino converts the analog voltage from the pots into a digital one for use with SMC3 code. Is it possible to modify the code so that the arduino reads the digital signal from the hall effect sensor rather than from the analog?
    The motor uses an AS5040:
    https://ams.com/as5040
    It has an SSI interface for the absolute and the following as well:
    Output Digital angle (interface) / ABI / UVW / PWM
  2. BlazinH
    16,680Coins
    I read that you need an interface to use ssi with an arduino. But the specs say it also outputs pwm. When an inexpensive low pass filter you can convert it into an analog signal. This usually smooths the signal out somewhat though.
  3. Qlittles
    226Coins
    Ah, so it sounds like it IS possible. I'll research n see what that ssi interface is. For the pmw, I'm guessing that smoothing out the signal is not optimal because of the loss of detail?
