SimXperience rFactor Tip - Multi-Processors
Discussion in 'Virtual Racing League' started by bvillersjr, Jun 7, 2009.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    rFactor is capable of utilizing multiple processors!
    Simply add -fullproc to the command line of the shortcut that you use to launch it and watch your FPS increase, which increases the drivability. 8)
    I have seen some posts that suggest that you add +fullproc as opposed to -fullproc. +fullproc does NOT work for me.
  2. pointer4
    pointer4 Member
    Hungary
    276Coins
    Yeah, it's me i told that.
    As I read the program makers (ISI) webpage.
    · Fixed dual processor timing issues by forcing game to only run on one processor. It can be overridden by using +fullproc in the command line, since Microsoft has now announced a fix for dual processors which is available only with Windows XP SP2.
    http://www.rfactor.net/index.php?page=1040whatsnew
  3. Dave Flick
    Dave Flick New Member
    502Coins
    Does that go after the rfactor .exe in the game exec line?
  4. bsft
    @Dave Flick , I suspect this information is way out of date now.
  5. Dave Flick
    502Coins
    thanks for the heads up.....i am trying to get info on the optimal settings for dirt car racing for my simexperience 2dof simulator
  6. bsft
