Question SimVibe output to sound card
Discussion in 'SimTools Pro & Entertainment Version' started by Margaritaman, Sep 21, 2019.
  1. Margaritaman
    Margaritaman New Member Gold Contributor
    Sales
    Southern California
    67Coins
    Motion platform
    I suspect this is going to painfully obvious, but...
    I have a separate amp that powers four Clark Transducers and when I was running SimExperience that program output sound to the 3.5mm output jacks on my computer and from there the signals went to the amp. All other sounds were processed through the Digital S/PDIF output.
    With SimTools I have it set up the same way but I've got no sound from the game itself (in this case Iracing), but everything tests fine with the SimTools output test feature. I've assigned the Digital S/PDIF soundcard inside of Iracing as I have in the past.
    Simtools is set up to utilize the 3.5mm outputs I'm just not getting a signal from the game.
    What part did I overlook?
    TIA
    150,686Coins
    +11,018 / 55 / -2
  3. Margaritaman
    Sales
    Southern California
    67Coins
    Motion platform
    I thought that would be the case. My issue is I run a vertical gpu so I’ll find some inexpensive external one.
    Thanks again
  4. Margaritaman
    Sales
    Southern California
    67Coins
    Motion platform
    Just like the link you attached. ;)
