Simulating movement in Solid Edge with SimTools?!?
Discussion in 'Off Topic - All other stuff here' started by My.stAr, Nov 29, 2016.
  1. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    have a simple question.
    Does anyone know, if i can use Solid Edge instead of SketchUp for simulating the movements with simtools?
    I'm used to Solid Edge and don't want to switch to sketchup just for a build...
    thanks
    150,728Coins
    +11,018 / 55 / -2
    I have not heard of solid edge being used.
  3. value1
    14,949Coins
    I would say yes you can, if you're patient and have some time.
    You can do pretty things with SE:
  4. My.stAr
    Engineer
    1,064Coins
    DC motor
    You mean with SimTools?! Or with the Solid Edge tools??
  5. value1
    14,949Coins
    With both. And you need to know first of all SE.
  6. RacingMat
    21,023Coins
    SketchUp and Simtools are communicating via a SketchUp's Ruby API
    As I don't see any Ruby API for SolidEdge, you may have to forseen a good amount of work to analyze SolidEdge APIs. :)
    https://github.com/SolidEdgeCommunity
    https://code.msdn.microsoft.com/windowsapps/Samples-for-Solid-Edge-790041df
    C++ and VB.net Samples for Solid Edge is a CodePlex project whose goal is to provide high quality examples of automating Solid Edge using .NET technologies.
    http://fr.slideshare.net/SiemensPLM/solid-edge-api-automating-solid-edge-basics-with-net
  7. My.stAr
    Engineer
    1,064Coins
    DC motor
    I'm using SE for other projects too. So i'd say i know SE;)
    Since there is atm no ready to use plugin, i'll forget about that idea.
    thanks for the answers!
