Simulate traction loss on 4 actuators setup?
Discussion in 'DIY Motion Simulator Projects' started by Scblacksunshine, Apr 4, 2020.
  1. Scblacksunshine
    Scblacksunshine Member
    270Coins
    2DOF, 3DOF
    Is it possible to simulate something similar to traction loss on a 4 actuators set up like the PT actuators or Dbox? I understand it won't be a true traction loss since it won't pivot without another axis. If so, what setting do you need to enable in Simtools to enable this? Yaw or Extra 1 or 2 if the plugin has it enable? thanks
    154,238Coins
    +11,176 / 57 / -2
    Not really, you can get a small sense with sway but that is the limit of the design.
