Showroom Simulador 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Titobial, Apr 25, 2017.
  1. Titobial
    Titobial Member
    Zaragoza
    159Coins
    2DOF, AC motor, Arduino, Motion platform
    Mi Proyecto Es Un simulador BASADO en Arduino, escudo moster, potenciómetros y motores ... ya estoy trabajando en la Estructura del chasis, la Fijación de muelle central, Conectores para el movimiento del motor y el asiento. Más tarde voy a subir más fotos del Proceso. ¡Un saludo!
    150,722Coins
    +11,018 / 55 / -2
    Google Translate -
    My project is A simulator based on Arduino, moster shield, potentiometers and motors ... I am already working on the structure of the chassis, the fixation of central spring, connectors for the movement of the engine and the seat. Later I will upload more photos of the Process. A greeting!
    You can dual language post on the main threads, but please include English via Google Translate.
    We have many dual language members so if Google Translate really messes the meaning up then other bilingual members can help translate.
  3. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Hi. But I have translated it manually from Spanish to English. How should I insert the language translator? Also, I do not have the option in my thread to edit my Messages.
    Edito: I already have the option to edit my messages. I'm sorry if any message has not appeared with the English translation. I'm sorry, but until now he would not let me. Health!
    150,722Coins
    +11,018 / 55 / -2
    Google Translation -
    Hi. But I have translated manual from Spanish to English. How should I megter the language translator? Also, I do not have the option in my thread to edit my messages.
    Please use Google Translate: https://translate.google.com/
    Chrome lets you view a page in your native language, but you need to post an English translation as well. There are plenty of plugin that can help with that, personally I use Google Translator for Firefox.
  5. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Let's see, I'm using the translator. I add the text in my language, transfer it to English, copy it and paste it into the message. Not worth that, it actually costs me more work! I ask you what I should do more .. ???
    150,722Coins
    +11,018 / 55 / -2
    This is an international forum where it was decided long ago that English would be the default language. That may not be fair but only you can decide if it is worth the effort on not as we have members from across the globe and for many English is not their primary language: https://www.xsimulator.net/community/memberMap/
  7. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Hello again. I know that the official language and for all is and is spoken in English unanimously, I understand perfectly. That is why I translate it into English before sending my message. But I do not understand why you answer me every time I send a message, I decide to use the translator, when I need you, I already do. What am I doing wrong? Many thanks again for your response. A greeting.
    150,722Coins
    +11,018 / 55 / -2
    I was answering what I took you meant by this comment:
  9. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Ah! Ok forgive It has been a missunderstanding. (If the translations are also understood other things) I do not mind translating my text, it was because I thought it was not worth the way it did ... then is it correct how to send my messages now? thank you very much.
  10. Pit
    30,477Coins
    @Titobial welcome here, your text and translation is fine, as @noorbeast has underlined written English is mandatory. Thank you.
  11. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Very well then, it seems perfect !! Many thanks!
  12. Titobial
    Titobial Member
    Zaragoza
    159Coins
    [Quote = "Pit, mensaje: 131338, miembro de: 8752"] [USER = 24657] @Titobial [/ USUARIO] bienvenido aquí, el texto y la traducción está muy bien, como [USER = 10786] @noorbeast [/ USUARIO] ha subrayado Escrito Inglés es obligatorio. Gracias. [/ Quote]
    Hi. I want to publish some more photos of my project. How is the best way to do it within my thread? Should I respond to the latest response and attach photos? Or is there any option to upload photos directly? I do not see him clergy. Thanks in advance. A greeting.
  13. noorbeast
    150,722Coins
    +11,018 / 55 / -2
  14. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Banco de pruebas con dos motores, potenciómetros y controladores ... Banco de pruebas con los ejes, potenciometros y controladoras..jpg
    parte Mañana del chasis y el asiento.
  15. Titobial
    Titobial Member
    Zaragoza
    159Coins
    [Quote = "noorbeast, mensaje: 131350, miembro de: 10786"] Puede subir fotos directamente y mantener el tamaño de archivo razonable, si son archivos más grandes y hay unos cuantos de ellos a continuación, utilizar la opción Miniatura al poner las fotos en una mensaje: https://www.xsimulator.net/community/faq/upload-pictures-or-files.81/ [/QUOTE]
    Thanks again mate. I already uploaded a couple of photos. Take care.
  16. Titobial
    Titobial Member
    Zaragoza
    159Coins
    chasis superior de aluminio. Donde se alojan la silla y los pedales.
  17. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Sillón que voy a utilizar, tomado de un Rover Coupe. Asiento copiloto de Rover coupe.jpg
  18. Titobial
    Titobial Member
    Zaragoza
    159Coins
  19. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Hello again! I would like to upload a small video of my system working ... (motors, controllers ...) but it does not leave me as a matter of size. Is it possible to upload a video directly from the pc? Thanks and regards!
  20. noorbeast
    150,722Coins
    +11,018 / 55 / -2
