Question SimTools vs FanaLEDs
Discussion in 'SimTools Pro & Entertainment Version' started by Deleted member 30486, Feb 23, 2019.
  1. Deleted member 30486
    Hey!
    Is it possible to have Simtools motion and FanaLEDs work at the same time in F1 2017?
    hardware_settings - option A - FanaLEDs works - Motion not:
    <udp enabled="true" sendRate="60" port="30500" ip="127.0.0.1" broadcast="false"/>
    <led_display sliProForceBrightness="127" sliProNativeSupport="false" fanatecNativeSupport="false"/>
    hardware_settings - option B - Motion works - FanaLEDs not:
    <udp enabled="true" sendRate="60" port="20777" ip="127.0.0.1" broadcast="false"/>
    I can change the 'port' setting in-game which changes the support from FanaLEDs to Motion or vica versa.
    I changed the 'port'-setting within the software of FanaLEDs to 20777, but this doesn't help...
    Thanks in advance!
  2. yobuddy
    50,353Coins
    try this buddy,
    if it does not work try this please,
    <udp1 enabled="true" sendRate="60" port="20777" ip="127.0.0.1" broadcast="false"/>
    I believe it should work.
    Take care,
  3. Deleted member 30486
    Tried both options (and the option: <upd0... <upd1... )
    No luck...
    The game probably reads both lines of code, but than re-writes the file with only the second (last) line.
    So with the options you've mentioned only FanaLEDs is working; port 30500.
    (again after adjusting the port-option in-game to 20777; the motion works and the leds don't)
    Update:
    Found this info on the codemasters forum: I will test tomorrow:
    https://forums.codemasters.com/topic/24138-f1-2017-and-multiple-udp/
  4. Deleted member 30486
    YES! It works :)
    Steps:
    - Download: "CodemastersProxyServer_v2.4.3.4" (see attachment)
    - Change Windows properties of "CMPX64.exe" (right click file/properties/compatibility)
    * run program in compatibility mode: windows 8 (Because I run Windows 10)
    * run program as administrator
    - Start "CMPX64.exe" (default opens minimized)
    - Right click on icon and choose "options..."
    - Change default: "Main Proxy UDP Port" to 20771
    * (therefore you don't need changes within Simtools and FanaLEDs)
    - Add (+) "Device UDP Port" 20777 with API 4 (for motion with Simtools)
    - Add (+) "Device UDP Port" 30500 with API 4 (for FanaLEDs)
    - Close the "Options" and exit the tool.
    - Change the file: hardware_settings_config of the game F1 2017
    * Default location: C:\Users\<username>\Documents\My Games\F1 2017\hardwaresettings
    * Change these lines:
    <udp enabled="true" broadcast="false" ip="127.0.0.1" port="20771" sendRate="60" />
    <led_display fanatecNativeSupport="false" sliProNativeSupport="false" sliProForceBrightness="127" />
    - Run FanaLEDs and Simtools
    - Run CMPS64.exe
    - Run F1 2017 and enjoye :)
    note: Always remember to run CMPS64.exe when playing ;)
  5. Deleted member 30486
    For it to work with F1 2018 change the UDP settings as followed:
    - Change the file: hardware_settings_config of the game F1 2018
    * Default location: C:\Users\<username>\Documents\My Games\F1 2018\hardwaresettings
    <udp enabled="true" broadcast="true" ip="127.0.0.1" port="20771" sendRate="60" format="legacy" />
    GameVibe, Motion and Fanaleds works all together.
