Simtools for linux ?
Discussion in 'Ready, set, go - Start your engines' started by fatimetou, Jun 20, 2019.
  1. fatimetou
    fatimetou New Member
    121Coins
    hello,
    I want to install on linux in order to combine it with CARLA simulator.
    My question is :
    Can i find simtools compatible with linux ?
    Thank you in advance :)
    154,322Coins
    +11,179 / 57 / -2
  3. fatimetou
    121Coins
    Thank you Noorbeast for this information ,
    Yes indeed Carla has an experimental version for window.
    Ok, I will try this option then :).
  4. Leandro Kemp
    Brasil
    - 10Coins
    Hi.
    Is it possible to use simtools on Linux?
    Another option would be to use Linux with windows running on Virtual Machine.
    It's possible?
    I tried here with Virtual Machine, but Simtools Registration won't open.
    Which version of windows worked on the virtual machine?
    I installed Simtools and plugins on windows 10 using a virtual machine, but the Simtools Registration window does not run. Any tips on how to activate Simtools by other means?
    Tank you.
