SimTools and Arduino Uno Micro servo
Discussion in 'DIY Motion Simulator Projects' started by Darkhanbaatar, Jan 23, 2014.
  1. Darkhanbaatar
    Darkhanbaatar New Member
    - 6Coins
    2DOF, DC motor, Arduino, 4DOF
    hi I have many problems, i used SimTools and Arduino Uno, Micro servo SG 90 arduino code is: RC_Sim_Model.ino file it didnot wort there is no any motion. what i do?
  2. Historiker
    Michigan USA
    9,214Coins
    before sending that code to your Arduino you have to comment (\\) out this line:
    #define DEBUG 1 // comment out this line to remove debuggin Serial.print lines
  3. Darkhanbaatar
    - 6Coins
    // RC Model Servo
    // Written By EAOROBBIE (Robert Lindsay)
    // For free use for Sim Tool Motion Software
    #include <Servo.h>
    Servo myservo1; // create servo object to control a servo
    Servo myservo2; // create servo object to control a servo
    char kind_of_data; // to capture which servo needs to be move
    int valLSP = 90; // set the intial Left Servo Position to centre
    int valRSP = 90; // set the intial Right Servo Position to centre
    void setup()
    myservo1.attach(3); // attaches the servo on pin 5 to the servo object
    myservo2.attach(5); // attaches the servo on pin 4 to the servo object
    myservo1.write(valLSP); // sets the servo position according to the scaled value
    myservo2.write(valRSP); // set the servo position according to the scaled value
    Serial.begin(9600); // opens serial port at a baud rate of 9600
    void loop()
    //****************************** READ DATA FROM SERIAL ******************************
    while (Serial.available() > 0)
    kind_of_data = Serial.read();
    if (kind_of_data == 'R' ) Read_RightServo();
    if (kind_of_data == 'L' ) Read_LeftServo();
    myservo1.write(valRSP); // sets the servo position according to the scaled value
    myservo2.write(valLSP); // sets the servo position according to the scaled value
    void Read_RightServo(){
    int RightServoPos = 0;
    delay(2);
    int RSP100 = Serial.read();
    delay(2);
    int RSP10 = Serial.read();
    delay(2);
    int RSP1= Serial.read();
    RSP100 = ((RSP100)-48)*100;
    RSP10 = ((RSP10)-48)*10;
    RSP1 = ((RSP1)-48)*1;
    if (RSP10 < 0 && RSP1 < 0){RSP100 = RSP100/100;RSP10 = 0;RSP1 = 0;}
    if (RSP1 < 0){RSP100 = RSP100/10;RSP10 = RSP10/10;RSP1 = 0;}
    //Serial.println(RSP100); // these are here for debugging purposes
    //Serial.println(RSP10); // these are here for debugging purposes
    //Serial.println(RSP1); // these are here for debugging purposes
    RightServoPos = RSP100+RSP10+RSP1;
    valRSP = map(RightServoPos, 0, 255, 0, 179); // scale it to use it with the servo (value between 0 and 180)
    //Serial.println(RightServoPos); // these are here for debugging purposes
    //Serial.println(valRSP); // these are here for debugging purposes
    void Read_LeftServo(){
    int LeftServoPos = 0;
    delay(2);
    int LSP100 = Serial.read();
    delay(2);
    int LSP10 = Serial.read();
    delay(2);
    int LSP1= Serial.read();
    LSP100 = ((LSP100)-48)*100;
    LSP10 = ((LSP10)-48)*10;
    LSP1 = ((LSP1)-48)*1;
    if (LSP10 < 0 && LSP1 < 0){LSP100 = LSP100/100;LSP10 = 0;LSP1 = 0;}
    if (LSP1 < 0){LSP100 = LSP100/10;LSP10 = LSP10/10;LSP1 = 0;}
    //Serial.println(LSP100); // these are here for debugging purposes
    //Serial.println(LSP10); // these are here for debugging purposes
    //Serial.println(LSP1); // these are here for debugging purposes
    LeftServoPos = LSP100+LSP10+LSP1;
    valLSP = map(LeftServoPos, 0, 255, 179, 0); // scale it to use it with the servo (value between 0 and 180)
    //Serial.println(LeftServoPos); // these are here for debugging purposes
    //Serial.println(valLSP); // these are here for debugging purposes
    that is my used arduino code, i used arduino uno and micro servo SG90
  4. Darkhanbaatar
    - 6Coins
    PLS insert tutorial RC_Sim_Model
  5. eaorobbie
    20,491Coins
    Ok I agree look like thats my project for tonight.
  6. Darkhanbaatar
    - 6Coins
    Hi i used SimTools and Arduino Uno, Micro servo SG 90 it is working fine just live for speed game and other games race 07, rFactor 1,2 dirt2,3 are working fine but arduino uno received signals (Led flashing) but output testing-virtual axis area have lesser sensation and micro servo don't move
    help me
  7. Darkhanbaatar
    - 6Coins
    Hi my simTools working fine Dirt3, Race07, rFactor, i used Arduino Uno, Micro servo SG 90.
    thanks help me.i'll make big one wiper motor or window motor
  8. eaorobbie
    20,491Coins
    The code will only drive servos, need to update code to several here on site, @prilad and @RufusDufus both have codes with nice tut and apps to setup them up.
    The rc code is for models only.
  9. Darkhanbaatar
    - 6Coins
    ok thanks i know it
  10. eaorobbie
    20,491Coins
    Gday @neotonight, please start your own build post so not to clutter @Darkhanbaatar topic.
    Then we can advise you which steps are next.
    Quick answers, 6 servos on one UNO, yes will work with a external power supply
    Yes 2 wipers per Ard UNO, some codes will run up to 3 , but to me Ard is not powerful enough to cope properly so I would recommend only using one ard for two motors.
    And last NO wont work.
  11. jsbuitrago
    jsbuitrago New Member
    42Coins
    hola estoy intentado realizar la conexion de simtools con arduino pero no he podido ver si se esta comunicando por la ventana serial le agradezco si me dan una ayua
  12. noorbeast
    153,107Coins
    +11,117 / 56 / -2
    Please be aware that you can dual language post but must provide an English translation, as per the Forum Rules, using Google Translate is fine: https://www.xsimulator.net/community/threads/forum-rules.9527/
