Question Simtools + 2 controllers
Discussion in 'SimTools Pro & Entertainment Version' started by Frada, Oct 12, 2021.
  1. Frada
    Frada New Member Gold Contributor
    69Coins
    2DOF, SCN5
    English
    Hello, can Simtools run 2 controllers at the same time? (1 thanos card for 4 SFX 100 + 1 drivers scn5 for traction loss)
    154,580Coins
    +11,190 / 57 / -2
    Yes SimTools can.
  3. yobuddy
    51,676Coins
    SimTools is able to run 6 as the same time should it be needed.
    Take care!
  4. Frada
    69Coins
    2DOF, SCN5
    Ok thanks!
    6 controllers or 6 actuators?
  5. yobuddy
    51,676Coins
    6 Interfaces/controllers total.
    If the interface/controller supports 6 actuators, then it will run 36 actuators.
    If the interface/controller supports 1 actuator, then it will run 6 actuators.
    Hope this makes sense man.
    Take care,
  6. Frada
    69Coins
    2DOF, SCN5
    Ok, I don't speak English and I use a translator but I understood your explanation very well, thank you friend.
