Question Sim tools - output testing directions ?
Discussion in 'SimTools Pro & Entertainment Version' started by Gadget999, Oct 3, 2021.
  1. Gadget999
    11,947Coins
    I wanted to check that the directions I have set are correct with the outputs
    so when you slide left the motion is in the right direction
    is this correct
    Roll - left moves sim to the left right moves the sim to the right
    Pitch - left pitches forwards right pitches back
    Heave - left goes up right goes down
    Yaw - left rotates left right rotates right
    Sway - left sways left right sways right
    Surge - left moves forwards right moves backwards
    150,686Coins
    +11,018 / 55 / -2
  3. Gadget999
    11,947Coins
    Hi noorbeast
    thanks for the link - what i am trying to clarify is which way surge is for example when the slider is pulled to the left
    150,686Coins
    +11,018 / 55 / -2
    Surge should pitch down under brakes and pitch up under acceleration, surge will normally be opposite of your pitch DIR settings.
