Showroom Sim Project - Kevin Stage 2 [SOLD]
Discussion in 'DIY Motion Simulator Projects' started by -kevin-, May 22, 2012.
  1. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    2DOF, 3DOF, DC motor, SimforceGT, 4DOF
    To start I do thanks to the communities of simulators from which I was inspired to build my sim ;)
    Big thanks adbgg!!! and from there I started :cheers
    Please do not send me PM or Email for more assistance if you want help, you can write in my post where they can read all including me and other users of the forum so you can help other people in your auto that have the same problem. Thanks ;)
    Building structure
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Finished Structure STAGE 1
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    YOUTUBE VIDEO STAGE 1
    Sorry for the quality of the video I made them with the cell I get the camera to be repaired ...
    then put in HD
    X-SIM TEST dinamic configuration speed
    Look at my son how to destroy a BMW :D
    Thanks for helping me to SirNoName for NoLimits Simulator Used x-sim 3 Stage 2 is phenomenal ;)
    X-SIM - Test n°1 - NoLimits Simulator
    UPDATE 01/08/2012
    STAGE 2
    Work carried out:
    Replaced hub central joint (the first was noisy) = DONE
    Replaced with a racing seat = DONE
    Added belts OMP racing = DONE
    Painted the whole structure = DONE
    Changed the pedals = DONE
    Replaced gear knob = DONE
    Added articulated arms for horizontal oscillation = DONE
    Added aluminum in the structure [/b] = DONE
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    YOUTUBE VIDEO STAGE 2
    Added dashboard with galaxy s4
    STAGE 3
    As soon as I find the time I need to finish the following improvements:
    Plexiglass protection for the mechanical parts in movement
    Bracket 42'' TV triple screen
    Brackets and 5.1 speakers
    Side panels and rear
    2° monitor TouchScreen
    Speedometer
    = DONE
    And finally, if I would like to add a third motor to simulate the loss of adhesion
  2. -kevin-
    128Coins
    Re: Blue Sim racing - 2DOF Wiper Motors K8055+Sabertooth 2x12
    FOR UPDATE
    Stage 3 under construction
  3. -kevin-
    128Coins
    FOR UPDATE
  4. -kevin-
    128Coins
    FOR UPDATE
  5. bsft
    Re: Blue Sim racing - 2DOF Viper Motor K8055+Sabertooth 2x12
    Thats a great looking sim there, a lot of time and care taken, looks great!
    Lets see how it moves!
    Cheers, David.
  6. floriske.nl
    floriske.nl Member
    Graphic Designer
    Netherlands
    27Coins
    Wow! That's a great looking sim, especially if you take the build costs into account :eek: guess you had to have some of the stuff lying around allready?
    I've scavaged for the cheapest I could find on a lot of parts (orders in china, hungary .....), but no way I'm going to manage my build within $ 600,- :tape: just my seat and the 2 JRK's are over half of that.
    But once again: Very nice rig!
  7. -kevin-
    128Coins
    thanks BSFT :thbup:
    In fact, I have taken away much free time since then I have the bad habit of not taking measures to draw the first I've undone and redone some things like the pedals and I have done everything in my mind things were as they did the work
    if I make it tonight or tomorrow I put videos on youtube so you can see how it moves in my opinion seems like a good car a real buzz :yippiee:
  8. -kevin-
    128Coins
    thanks floriske.nl ;)
  9. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    Fantastic build m8 :clap:
    I really like how everything looks, neat and simply AWESOME !!!
  10. -kevin-
    128Coins
    Thanks fermevc :thbup:
  11. furlo88
    furlo88 Member
    - 10Coins
    Oddio O_O non ho ancora fatto in tempo a leggere tutto, sta sera mi metto lì e traduco , è venuto strabeneeeee !!! complimenti !!!! spero che anche il mio venga simile !!! che invidia :yippiee: ti faccio i miei complimenti !!!!
    O_O Oh I have not had time to read everything, tonight I sit there and translate it, came strabeneeeee! congratulations!! I hope that my be like! that envy yippiee: I congratulate you!!
  12. -kevin-
    128Coins
    Grazie furlo88 :thbup:
    Per la traduzione ti consiglio questa estensione per firefox https://addons.mozilla.org/it/firefox/a ... ictionary/
    traduce in un attimo tutte le pagine web in qualsiasi lingua basta andare sulla barra di foxligo e cliccare autotraduzione ;)
    Thanks furlo88 :thbup:
    For the translation I suggest this extension for firefox https://addons.mozilla.org/it/firefox/a ... ictionary/
    results in a moment all the Web pages in any language, just go to the bar and click foxligo self-translation ;)
  13. furlo88
    furlo88 Member
    - 10Coins
    allora ho letto la guida ed è fatta bene complimenti ! non vedo l' ora di vedere il video sono curioso.
    avrei alcune domande , se puoi rispondermi quando hai tempo mi fai un favore grazie
    partendo dall' inizio
    1) il mozzo (chiamiamolo così) centrale sotto il sedile , lo hai fatto tu? perchè non capisco come trovarne uno
    2) come si chiama quell' occhiello che fa da albero dal motore al sedile ? non riesco a trovarlo.
    3) gli ingranaggi da dove arrivano :D
    4) il motore hai dovuto modificarlo collegandogli solo l' alta velocità ? o lo hai lasciato originale
    5)caiubbo aveva messo un diodo da 40A nell alimentatore affinchè la sabertooth non facesse tornare indietro la corrente, ma nello schema io non l'ho visto.
    6)la resistenza che bisognerebbe mettere nell ATX serve per stabilizzare la tensione, tu non l hai messa vero ?
    7)non ho tradotto bene la parte dove dicevi che prima di spegnere il software sim devi premere l'emergenza in modo da spegnere l'alimentatore se no succedono disastri ho tradotto bene ?
    8) se vuoi puoi mandarmi a stendere per tutte le domande che ho fatto :cheers:
    no veramente scusa il disturbo
    Then I read the guide and is well done congratulations! I 'm looking forward to seeing the video I'm curious.
    I have some questions, if you can answer when you have time to do me a favor by
    starting from 'start
    1) the hub (let's call it that) under the middle seat, you did? because I do not understand how to find a
    2) how THAT is called 'eye that acts as a shaft from the engine to the seat? I can not find it.
    3) the gears where they come: D
    4) you had to modify the engine collegandogli only the 'high speed? or did you leave the original
    5) caiubbo had put a 40A diode in power supply so that the Sabertooth did not turn back the current, but the diagram I have not seen it.
    6) the resistance that should be put in ATX serves to stabilize the voltage, you did not you put it?
    7) I have not translated well to the part where you said that before turning off the software sim you have to press the emergency to turn off the power supply if no disasters happen I have translated well?
    8) If you want you can send me to lie down for all the questions that I have done: cheers:
  14. bsft
    Yes you have done very well with overall costs. Its hard to build a sim for under $600 unless you have the steel already and can find everyhting else cheap.
  15. nota
    nota New Member
    Grande.....tutti i miei complimentoni sia per il progetto che per la guida... :clap:
    Great ..... all my complimentoni for the project which the guide ... : clap:
  16. estanislaolopez
    estanislaolopez Member
    Argentina
    56Coins
    2DOF, DC motor, SimforceGT
    Hi Kevin great job!
    Very good guide, will help more than one in the building ....
    Enjoy it!
    Congratulations! :cheers:
    Pablo
  17. -kevin-
    128Coins
    Thank you all very kind :cheers:
    Ho messo qualche video di youtube ;D
    No! I bought the hardware is basically 2 pieces and welded them together and I do not know how I found them exposed test call to see if they are within a vai autodemolzione and take a linkage
    They are called knuckles and these also find them at hardware stores
    3) the gears where they come :D
    The gears have them taken by a servo-control of a three-way valve
    You must use the green and brown wires lalta speed forever if you take the same engine as mine
    else is written in the guide though it may be that translating is not clear :D
    The schematic that I posted and as you see it without diode perhaps because he has served different motors are 24V or went into a tailspin the pc atx 400w seems to me ... and uses it for everything .... I use a power belonging to 30A
    Yes! I did not put because as mentioned above using power belonging
    Yes! You must first switch off the button or switch, and because x-sim, which controls the motors and closing it first should be at full speed by breaking the mechanical potentiometers
    8) If you want you can send me to lie down for all the questions that I have done :cheers:
    not really excuse the disorder
    Quiet ... I did the same thing ;)
    I put some videos in youtube ,D
  18. -kevin-
    128Coins
    Let's say I tried to save as much as possible by buying only what you need and all the rest of recovery ... less than $ 600 I see a little difficult ..
    I had something then the closing spring steel fan atx electrical box that is nothing but a stereo speaker engines have donated them to me etc. .. etc. ..
    If I bought all cost much more
    I think for a simple structure like mine are from $ 600 to $ 800
  19. riton
    riton Active Member
    1,006Coins
    i try to test my Saber card with my VM110, and i have some problem With Dynamic speed, is possible to see screen to the setting?
    I need some information about the dynamic speed config
    http://youtu.be/m2Wam3VY0-U
    Thanks!
  20. bsft
    That sort of cost would be about right....
